Ball joint replacement, axleshaft removal
Hey guys, Currently replacing my ball joints on my 82 since I had to drill & chisel my camber eccentrics out a while back, and I am having trouble getting the passenger side axle shaft out. My drivers side slid out with no problems, my passenger side wont budge. I see they have this thing on it but I am not sure how to remove it. Or do I have to unbolt at the pumpkin & remove anything inside? I did this job on my 96 a while back but the passenger side wasn't set up like this. Help would be appreciated!
EDIT:
Got it out, apparently up until around 83, you need to unbolt the retainer at the pumpking, then the axle shaft should slide out, mine needed some persuasion with a BFH but it did the trick. Ones with no retainer, you need to unbolt the clamps at the cv joint to remove the passenger side axle shaft, and to remove the stub shaft, you must open the pumpkin and remove the retaining clip. Hope that helps for anyone that may encounter the same frustration that I just did!
I also found that my drivers side axle shaft needs a new U-joint, and I also had to go hunt down the big rubber seal that's on the end of the axle shafts for both sides. It's been slow going and a lot of running around. It went much easier on the 96 truck I did this job on, and that truck was way way way more rusted!
Spicer parts and MileMarker premium hubs for the win(ter).
I am currently waiting for the rain to pass so I can finish putting everything back together, hopefully tomorrow
HUNTING F150
08-22-2021 07:42 PM
loudfords
08-03-2011 10:03 AM
