2000 mountaineer odd issue
ok after getting the device this is what i got on a test without it messing up and after driving for about an hr
Mode $06 report generated by Torque for Android
Vehicle VIN: Not present
Vehicle Manufacturer: Unknown
Vehicle Calibration ID: Not present
Unit and scaling information are not supplied with the data from the ECU for this type of vehicle. Consulting the manufacturers service book for this information is recommended.
Test report:
TID:$01 CID:$11
- Rich to Lean sensor threshold voltage(constant)
Min: 512
Test result value: 776
PASS
TID:$01 CID:$21
Min: 512
Test result value: 744
PASS
TID:$03 CID:$01
- Low sensor Voltage for switch time calculation
Min: 0
Test result value: 461
PASS
TID:$03 CID:$02
Min: 0
Test result value: 512
PASS
TID:$10 CID:$11
Max: 45
Test result value: 41
PASS
TID:$10 CID:$21
Max: 51
Test result value: 32
PASS
TID:$41 CID:$11
Min: 64,640
Test result value: 65,387
PASS
TID:$41 CID:$12
Max: 896
FAIL
TID:$45 CID:$20
Max: 20,800
Test result value: 12,812
PASS
TID:$4a CID:$30
Min: 768
Test result value: 4,771
PASS
TID:$4b CID:$30
Max: 26,214
Test result value: 16,435
PASS
TID:$53 CID:$01
Test incomplete or dependant test failed
TID:$53 CID:$02
TID:$53 CID:$03
TID:$53 CID:$04
TID:$53 CID:$05
TID:$53 CID:$06
TID:$53 CID:$07
Max: 0
Test result value: 48,670
FAIL
TID:$53 CID:$08
Max: 0
Test result value: 6,061
FAIL
TID:$53 CID:$09
Max: 0
Test result value: 800
FAIL
TID:$53 CID:$0a
Max: 0
FAIL
End of report.
Test report:
TID:$01 CID:$11
Min: 512
PASS
TID:$01 CID:$21
Min: 512
PASS
TID:$03 CID:$01
Min: 0
PASS
TID:$03 CID:$02
Min: 0
PASS
TID:$10 CID:$11
Max: 45
PASS
TID:$10 CID:$21
Max: 51
PASS
TID:$41 CID:$11
Min: 64,640
PASS
TID:$41 CID:$12
Max: 896
FAIL
TID:$45 CID:$20
Max: 20,800
PASS
TID:$4a CID:$30
Min: 768
PASS
TID:$4b CID:$30
Max: 26,214
PASS
TID:$53 CID:$01
TID:$53 CID:$02
TID:$53 CID:$03
TID:$53 CID:$04
TID:$53 CID:$05
TID:$53 CID:$06
TID:$53 CID:$07
Max: 0
FAIL
TID:$53 CID:$08
Max: 0
FAIL
TID:$53 CID:$09
Max: 0
FAIL
TID:$53 CID:$0a
Max: 0
FAIL
End of report.
marvelouzone
07-16-2022 11:24 PM
AMiller320
12-18-2002 03:00 PM
