1979 F150 4x4 Build (pics)
#586
Wow. I applaud your attention to detail, and I did not know that. Thank you for sharing that info. Do you know what the other style of wheel weight is called? (The one that sticks on the inside of the rim)
Also, thank you for the compliments! I can’t get over how supportive the FTE community is. You guys are all so awesome!
#587
on
I'm hoping to have a really good tuning / thread update session sometime in July here. The back yard is almost done!!!
So what's next on your build man??? I'm curious where this progress will lead you to.
#588
Ha! Thanks for the encouragement Ben. I've actually taken a break from the truck since I had it running in May. Been doing a large amount of landscaping in the back yard and have had to put some of the truck plans on hold temporarily.
Right now, I really just want to get my issue with hot starts figured out (so I can drive it) and then I'll probably do the same thing you did. Take a break from working on it for a while so I can work on my house and yard.
I still need to wet sand and buff my paint job, and I have to clean and polish all of my dent and racetrack trim. I also need to get around to doing the raptor-liner in the bed.
Lots of finishing touches that will take some time.
#589
I'm going to have to shift my focus toward house and yard work pretty soon myself.
#590
I ordered a new ignition module, if that doesn’t fix the problem, it’s probably the coil.
#592
#593
Sorry if I hijacked your thread. But to answer his question: my truck is a 77. At some point the previous owner smashed in the driver’s door and repainted the whole truck, switched out the grille for a 79 because he liked the newer look. If he would have put FORD on the hood I may have just keep that 79 grille. My favorite years are 76&77 so it worked out.
Brad sxt
01-06-2017 01:54 PM
create
34
12-11-2006 11:44 AM
