5.8 Water Pump
5.8 Water Pump
1996 F350 5.8 351
every once in a while i hear a chirping sound from what i believe is the water pump. its just a chirp or two while at idle on very rare occasion. this has been happening for about 9 months now. i pulled the belt and the bearings are nice and tight with no play. the pump also keeps the truck cool, so no concern over its performance. it's just that chirp that makes me nervous.
It is the original pump and has 110,000 miles on it. i plow with the truck and can't afford a breakdown. So now that winter is on its way, i think that if nothing else, it would be good preventative maintenance to install a new one.
i can get pumps anywhere from $15 up to around $100. i want a high quality pump that will give me another 100,000 miles of trouble free service. I don't want to go cheap, but i also don't want to spend more than i have to. any specific pumps you recommend?
Rock auto has an Airtex pump, it's the heavy duty version, for $46
AIRTEX Part # AW4044H <INPUT id=node499part7moreinfo class=moreinfo_default title="Click for more information about this part" value=Info type=button> Includes Gasket
OPTIONAL HEAVY DUTY VERSION
I was told that my 2000 7.3 came from the factory with a Airtex pump with fords name on it.
thanks for the info. a lot of times certain aftermarket part producers may in fact be the OEM supplier.
so if i can spend $50 on an airtex pump versus over $100 from the dealer for the exact same pump with a "motorcraft" stamp on it, then the decision is a no brianer.
anyone else know of airtex being a Ford OEM supplier? or have any other opinions on pumps?
If you don't need the gasket kit then you can return it. And the front crank seal I suggested just because if you pull the timing cover you might as well take 2 minutes to replace that as well since it's already in your hands.
DAVID'S97F250HD
10-14-2010 11:18 PM
