1985 Bronco build
Old 11-23-2014, 09:45 PM
nytling92's Avatar
nytling92
nytling92 is offline
Did you buy that down by Louisville? I was looking at that one and emailed, never heard a response so I figured it was sold.
Old 11-24-2014, 04:14 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Putting this seats in the bronco? If so I thing the Supercab brackets are why you want
Old 11-24-2014, 07:10 AM
SVTDriver97's Avatar
SVTDriver97
SVTDriver97 is offline
Originally Posted by BiGGreen350
g
the 4.10 set will go in my 97, and my 97s original 3.55 set will go in the bronco, and i will sell the king pin one tons
I'm interested in the king pin axle. If you still have my number, give me a call and give me some more info about it. Otherwise I can call you?
Old 11-24-2014, 07:17 AM
BiGGreen350's Avatar
BiGGreen350
BiGGreen350 is offline
the brocno? yeah it came from louisville, only paid 980
yes seats are goin in the bronco. I have bronco tracks and brackerts too, but supercab brackets are or are not what i want?
give me a call whenever man
Old 02-16-2015, 01:50 PM
BiGGreen350
seats plans changed. grey seats are going in the 84, already removed all the supercab hinges and brackets, cleaned them, switched bottom foams side to side. and installed reg cab sliders hinges and brackets to go in the 84
Becuse i just bought some lightning obs 40 20 40 seats!
seats are literally perfect. i will still shampoo them. came out of a 40k mile lightning. guy has been building it for 14 years. seats were wrapped in plastic and in storage for that long.
plastics are perfect, console is perfect no rips burns or stains at all anywhere. im so happy with these and think they will look awesome inside this thing. interior will be black or gray.
the lightnng seats are getting all th supercab/bronco hinges, sliders, and brackets so they mount and function like they should and allow access t rear seat.
have some questions on the harness though brad if you could shed some light or explain how you have wired yours in past. it has two pig tails under the seat(not including the one that plugs into the harness that clips into the 40 20 40 seat pan) one is blue one is black.
anyways here are some pics.. already started taking them apart for cleaning and switching out of hinges and brackets and sliders.
and a picture of the supercab hinges to explain why i need them, they have an extra arm that connects a rod from the sliders to allow for rear acces when seat folds forward, it pulls the rod and releases the slider to slide seat way forward.
the supercab brackets and hinges and sliders im using on the lightning seats:
now the lightning seats!
and the wiring im asking about:
Old 02-16-2015, 01:54 PM
BiGGreen350
<table class="tborder" id="post15092876" align="center" border="0" cellpadding="6" cellspacing="1" height="4108" width="897"><tbody><tr> <td class="thead">forgot to put a picture of the original seats i was gonna used after they were cleaned and converted to go in the 84
the 84:
and the seats for it:
</td> </tr> <tr> <td class="alt2" style="padding:0px">
</td> </tr> <tr> <td class="alt1" id="td_post_15092876">
</td></tr></tbody></table>
Old 02-16-2015, 02:22 PM
Diesel_Brad
I have no idea on the second plug. in the harness
One plug is for power to the seats for the lumbar
The seatbelt typically have their own separate plug for the seatbelt light.
those lightning seats look good.
Did you just swap the "20" sections lower frames to work with your applications?
Old 02-16-2015, 02:38 PM
arctic y block's Avatar
arctic y block
arctic y block is offline
Great build. Subscribing
Old 02-16-2015, 03:11 PM
BiGGreen350
Damn. i have the harness that clips into the seat bracket and that has its own plug off the seat harness. the two that i pictured are a little further up than that one and i was confused on the blue one and the black one. now that you mention it the black one looks like the normal seatbelt one. the blue one is i have no idea. ill throw power and ground to it and see what i find.
yeah i am happy with the lightning seats. awesome shape, will look even better after shampooed
yupp on the 20 lower frame. just unbolt the arms for the upper part. and slide it off and put other one in.
Thanks!
Old 02-16-2015, 06:21 PM
Deadsquiggles's Avatar
Deadsquiggles
Deadsquiggles is offline
Definitely subscribing to this
Old 03-16-2015, 04:40 PM
BiGGreen350
sold the trans, transfer case, and nine inch rearend out of it.
Entire drivetrain and axles are all gone.
next step is once i swap my axles on my 97 to mock up the one tons on this.
bought motor mounts for the cummins too
getting the trans out was a blast!
Found out what was wrong with the motor. knew it was blown when i bought it
The number 1 cylinder piston was in the oil pan in pieces.
the oil pump shaft was bent like a "s"/ the two rear most cylinder must have spun a bearing and were seized to the crank.
Had to unbolt the main and rod journals, beat the pistons up into the cylinders, and Andy beat the ever living **** out of the crank to finally get it out, all so we could get the torque convertor off.
I have made 550 bucks on this bronco so far, selling all the crap i didnt need.
here is my list: bought the bronco for 980
Sold:
Wheels and tires 400
front axle 225
front seats 150
rear axle 250
rear sport bumper 150
trans and t case 350
+545
here are some pics.
big thankyou to Andy (DazedandConfused) for all the help, His giant self comes in handy
Old 03-16-2015, 08:27 PM
4x484150's Avatar
4x484150
4x484150 is offline
Nice "new" project!
  #28
Old 04-28-2015, 02:58 PM
BiGGreen350
got some wheels and tires for it. was a good deal from a friend that wanted something different so I got em.
BFG all terrains
305/70/16 load range E
two are 3 months old and two are 75%
came with centers and lugs.
on eagle alloy 058s
  #29
Old 04-28-2015, 03:14 PM
1986F150six's Avatar
1986F150six
1986F150six is offline
Those look nice!
  #30
Old 04-29-2015, 09:02 AM
Blue Rebel's Avatar
Blue Rebel
Blue Rebel is offline
lookin good man! Question for ya, what are your plans for those stock wheels off the 87?
Quick Reply: 1985 Bronco build
