Stolen truck
The truck was stolen from my driveway under the security lights in the only gated community in the county I live in. It was found setting and running the next day one county over in front of a house where the police said they left my truck and stole another that had as much tools on it as mine (easist thing to sell at a pawn shop is tools). Im afraid I would get lazy and not turn a kill switch off from a fuse off. Thats is why I need a wiring diagram for the starter circuit. I would like to put another switch in place when I turn the key to the start position it would put fire to this hidden switch I could hit that switch the truck would start and shut off with the key. I would like to do this under dash. Thanks for your thoughts and replies several good ideas just not the direction I would like go in. Again Thank you all.
I've been tinkering with your idea and needed a few clarifications. It appears as though the vehicle will start regardless of the position of the switch? It will kill the engine when you step on the brakes and sound the horn and lights, but only while the brake pedal is pushed right? Seems if they did that a time or 2 they would figure out that all they have to do is clip a wire from the brake pedal and drive away.
I did have to rearrange the relay wiring to get it to work at all so maybe I have it all wrong. Was using a ford relay foab-14b192-aa which from as far as I can tell should be in line with what you are doing.
Used to do them all the time.
1. Use a 12 VDC Automotive 5-Pin Relay SPDT 30/40A Bosch Type
Wire as follows:
Cut the Load Side of Fuse #30 and connect it to #30. Attach the new load side to pin #87 on the relay.
Tap the Brake Pedal Switch Wire (Green w/ Red Tracer on a 99.5) and attach to Pin #85.
Run a wire from Pin#86 to a Single Pole Switch and place it where you like out of sight. From the other pole on the switch, run to Ground.
If you like, run a wire from 87A to the Horn and/or Lighting Circuit.
When the switch is OFF nothing happens.
When It's ON and the Brake Pedal is depressed, the engine will shutdown nor will it start, the Horn will sound and the Lights will turn on.
I generally leave my truck running from when its started until I'm done for the day unless I'm on a long troubleshooting job. Along with a fast idle, it stays cold in summer and warm in winter when I get back in.
Wire as follows:
Here is a quick drawing as I have to Bug Out.
This setup doesn't switch off the pcm when the switch is off. Only when the brake pedal is pressed with the switch turned on. And the horn and lights only go when the brakes are on, then stop when you let off?
That's how I have tried it. Either I don't understand the function, or using the wrong relay. I'm using a foab-14b192-aa relay which I pulled out of the horn or something, common fuse in these vehicles.
You want one where #87 is Normal Closed (NC) and #87A is Normally Open (NO). When #85 has power to it (in this case from the pedal switch) and #86 is ground, the poles open #87 removing power from the IDM and Closing #87A which sends system voltage to the Horn/Light Circuit.
However, on the way home I was thinking, if you're just trying to keep some one from starting the vehicle, just put a switch on either the feed or the load, when the circuit id open (Off) there is no power to the IDM.
PATS is a nightmare... Why would anyone in there right mind want to swap that IN...
Removed that nightmare from my wifes Excursion...
#29
191124x7
2017+ Super Duty
02-22-2019 11:49 AM
53pickemuptruck
06-01-2012 10:42 PM
frdf250
02-27-2012 08:26 PM
Imaoleguy
1999 to 2016 Super Duty
09-23-2005 02:44 PM
