Ok, I swapped for some 75W-140 and it says "limited slip" on the label and on the back is says blah blah for hypoid differential and limited slip use blah blah. So, I'm assuming I won't need any other additives.
I think I have been getting some "chatter" from it already due to low fluid. It will like the rear end is bumping sometimes especially making a slow turn.
you probably need some more friction modifier added.
