<Sob>My truck getting worse instead of better
#92
Hope you saw the rest of my last post, I edited a couple of times.
I haven't tried to restart today, but when I did a bubble test, it cranked just like it did before the runaway so I suspect it'd start again. And, it seems like it'd idle for as long as I want. It's only when I give it pedal that all hell breaks lose.
I call it a runaway because I turn the key off and it keeps running at real high rpm.
Sorry for being a layman, but what do you mean by "CCV tube pulled out." Nor do I know what "blow by" means, but I've heard the term and will google it right now. Also, what is a "leak down test"?
Dang, I feel like an idiot.
Again, SDS seems like a great tech, but there has to be a good tech here in Houston as well. Towing a truck 1200 miles to get worked on seems kinda pricey.
Blow by is oil vapors escaping past the piston and .
#93
My son-in-law just asked a question - sounds crazy, but all of this runaway stuff started when I hooked up the new scangauge I bought. Right after I put the engine back together from retorquing the injectors, I connected the scanguage and programmed in some X-guages. But, I've never done that before and am not positive I did it correctly. Also, I bought the SG used off of ebay and don't know what was programmed into it before. I started it for the first time and headed to the gas station and it died on the way. Figured I was out of gas, put some in, started up again, and it ranaway. The SG has been plugged in since then although I haven't even looked at it.
Could something in that SG be screwing with my computer, or commanding something off/on that shouldn't be?
#94
I would want to rule that out also. The ccv (crankcase ventilation) tube that connects to the driver valve cover and feeds into the tip (turbo inlet pipe) could've caused the inner cooler to fill and this would explain everything. Points to Chuck!!!! Definately have the oil fill cap off on the next start up.
I'd remove the cac (charge air cooler) cold side tube. That is the elbow that points to the driver side and try it again. If it doesnt take off with it not connected,, then you can try and run a couple shop vacs,, one on output blowing into one side,, the other vac sucking on the other side. Or you could just pull the cac. Lol.
#95
Did notice some wetness in there when I was putting it back together yesterday. Tried to dry it out. Also noticed that the turbo fins were cleaner than before the runaways, as if fuel was going through them and washing them off.
#96
just thought to look at the codes. SG says 7 codes but only shows these: P0113, P0472 P0134 and c3201
I'll go look them up
#97
[QUOTE=Super Duty Service;14759939]I would want to rule that out also. The ccv (crankcase ventilation) tube could've caused the inner cooler to fill.
HOW WOULD IT CAUSE IT? BEING PLUGGED UP, OR JUST BEING THE WAY BLOW BY WAS MAKING IT INTO THE TURBO?
TO SEE IF SMOKE COMES OUT? COULD I SEE THAT SMOKE BY JUST CRANKING IT, OR DOES IT NEED TO START? (STARTING IS SCARY).
YOU MEAN TRY IT WITH COLD SIDE OFF, AND IF IT DOESN'T RUNAWAY WHEN I GIVE IT PEDAL, THEN PULL THE OTHER SIDE OFF TOO AND TRY TO GIVE IT EVEN MORE PEDAL? I HAVE ONE SHOP VAC AND SEVERAL SMALLER VACUUM CLEANERS. DOES THE CONNECTION NEED TO BE SEALED OR JUST A LOOSE BLOW/SUCK IN THE RESPECTIVE TUBES? I ASSUME BLOW INTO DRIVER'S SIDE/SUCK ON PASSENGER SIDE?
WHERE IS THE INTERCOOLER?
#100
#103
P0134 is an oxygen sensor code......your truck doesn't have one!
P0472 is an EBP sensor code....Next to the T-stat housing. Easy to break it if your not careful.
P0113 is an IAT sensor code... You have 2 of these sensors.
C3201 is a seat belt code....
Check the connectors on the engine for the IAT and the EBP and clear the codes.
#104
One HEUI 6.0L injector cutaway with labeling.
HEUI Injector
The page where that image came from.
http://www.intellidog.com/dieselmann/injector.htm
Sean
HEUI Injector
Sean
