Some pic's of the 51
10-13-2014, 03:07 PM
on
The rear frame was notched.Put spring under axle.
10-13-2014, 03:11 PM
on
Not sure how to add more at one time got to work on it.
This the homemade motor mounts and the little 302 with a little warm up!!
10-13-2014, 03:15 PM
on
This the rear Trans mount. a little over kill but beef is good!!
10-13-2014, 03:41 PM
on
Nice!!! Keep up the good work!
10-13-2014, 05:02 PM
I would probably add some more metal above those notches. That took a lot of the bending strength out of that frame.
10-13-2014, 05:19 PM
on
Quote:
Originally Posted by
christurney77
Thanks !!!
10-13-2014, 05:21 PM
on
Gicknordon
You are right need to take a better looksey at that add more beef!!
10-13-2014, 05:41 PM
What valve covers are those? Looks pretty neat with the old school stickers.
10-13-2014, 06:03 PM
on
Gicknordon
I looked again forgot that I did put 1/4 inch steel pipe in the radius. should have some help there.
10-13-2014, 06:05 PM
on
Gicknordon
I got the valve covers off the Bay!! Can't remember where. Just trying something different they are aluminum painted.
10-16-2014, 10:23 AM
on
What is your front end and rear differential out of?
10-17-2014, 02:33 AM
on
fortuneflyer8
The Front end is a Jag, The rear end is stock Dana. With the 5 speed I think the rear end will be fine.
10-17-2014, 05:34 AM
on
barnfind 51
Right on. I'm trying to fit a 05 crown vic front and rear under mine. Did you change the gears in your rear end? I have a friend running a 302 with a c6 and he said the gears are really low. Just food for thought.
10-18-2014, 04:55 PM
on
fortuneflyer8
I think with the 5 speed it shouldn't be to bad. We will see when finished.
If it is to low no problem to up grade.
nos487
07-04-2011 02:22 PM
fordsrgrt
Iowa Chapter
04-19-2011 07:42 PM
TheTinian
Offroad & 4x4
28
05-26-2009 01:07 AM
needhelp49
05-09-2009 08:02 AM
1975StroppeBaja
West Virginia Chapter
10-24-2008 05:59 AM
