Got a parts truck 96 psd the guy said it had a cracked block .later found it was only the cover its prety bad or eles i would weld it. i found a shop in Denver that said they have one off of a 2000 if i pull it for twenty bucks. and the engine isn't in a truck so ya.
So that front cover off of the 2000 was a bust. it was broke in the same spot sucks . on the bright side i do have obe now it came off of a 94 is this one compatible or what's mods need done to it for it o work .
I can't see why it wouldn't work. But I don't know for sure. The hpops on the 94-5 was different than the 96-7. The 94 hpop had a check valve in the hpop and the 96 has it in the block. I don't know if the passages at the same through the covers or not. That probably why most on here are a little unsure if this is doable. I'm sure someone knows just hasn't seen the post
Check the surface where the hpop goes on.the earluer cover is very different.the gaskets are very different.if you have the wrong one it will leak down fast from the resivour.compate the old and new pattern.its very obvious
