CAB CRANE
on
CAB CRANE
I'm a member of HOMEMADETOOLS.COM it's a neat site that shows some of the exertise and enginuity of home grown problem solvers.
this last email showed a CAB CRANE that was posted by Jim Rizzo at CLASSICTRUCK magazine. really nice design that most of use could build or have built and it's a safe way to do the cab removal... sure beats my cherry picker and landscape timbers... here's a link
Homemade Cab Crane
you might also check out homemadetools.com for other good stuff...Ken has done a great job of gathering, catagorizing and organizing all the entries.
later
john
Homemade Cab Crane
later
john
An easier way to lif a cab is by lifting thru the side window. just put a straight extension on your engine hoist, either wood or pipe. It is high enough about the center of gravity that it will not be balancing,
You can put a piece of wood through both windows with blocks so it can't slide and something to keep your boom extention centered ish.
Not wanting to hijack the thread but since Ross mentioned it, I'll throw the picture back up. The secret is using chains and adjustable links of some kind to maintain a level even load on the cab. My hoist is a larger unit and it did the job with ease. I also used it to remove and install a front clip from the F4. Truly, a one man job.
I did it the same way but had 4 friends over - I directed while they did the heavy lifting ! Works really well
Homemade Cab Crane
later
john
Homemade Cab Crane
later
john
Thanks, I really appreciate the kind words.
I know this thread is an older one, but we appreciate the link!
To celebrate our 20,000th homemade tool, we made a new ebook featuring our top 50 homemade tools. You guys are welcome to it for free:
http://download.homemadetools.net/50MustReadTools.pdf
