gas pedal
gas pedal
i am putting a new motor in to my 68 f100 stepside........ and was wondering how the gas pedal was going to work...... i can't seem to find a kit to adapt my floor petal....... any ideas....... i was also looking at lokar they make a petal you can put in that is cable operated has any one used this petal? if so what did you think?
i have a IL6 in there now i am putting a 289 in( will any of the old brackets work?) i would like to try and keep my petal and not put a new one in
jason
jason
gas pedal
I've got a 351W (stroked393) in my 69 with Holley 750 and Edelbrock torquer II intake. Removed the stock linkage all the way back to the arm coming up from the firewall/pedal and using a FORD threaded shaft rod setup from carb to rear arm. I've got the summit front carb mounted return spring kit and works great.
gas pedal
thats about the same set up i am going to go with i am gonna go with a 600 cfm edelbrock carb.. and i am thinkin about the edelbrock air gap intake
where would i get FORD threaded shaft rod ?
do you know the part number on that summit part i hate getting the wrong parts.
thanks
jason
thanks
jason
gas pedal
I got the accelerator pull rod from my local ford parts dept, I'll check today and see if I can find you a part#. The summit spring kit I used is for Holley 4150/4160 carbs only but I'm sure they make one for your Edelbrock if you do a web search.
gas pedal
If you have the money, I would go with the cable. On the bright side, if you cab tends to move a little (i.e bad cab mounts) it won't affect it.
On a side note, sometimes up here in SD with our wonderful winter weather, If I am driving down the highway when there is a lot of blowing snow, my pedal tends to stay on the floor when I go to slow down (get outta my way!!) I assume that the engine is warming it up enough for snow to stick to it, but then it freezes. I can usually pull it up with my foot, but I would like to know if anyone else has experienced this and if there is an easy fix, thanks.
Hunt89
17
06-25-2012 02:38 PM
hayden01
02-06-2010 04:51 AM
kyleca1
03-17-2004 05:12 PM
