Are the front and rear brake drums interchangeable on 48 f2?
Old 10-02-2014, 01:37 PM
maestro1024's Avatar
maestro1024
maestro1024 is offline
I need to replace a rear on my 48 F2. It is rusted out real good.
But as far as new parts in the parts catalogs I mostly see just the front drum.
Can I use a front on the rear? Or does anyone have a good lead on a rear drum?
Thanks
Old 10-02-2014, 05:45 PM
FortyNiner's Avatar
FortyNiner
FortyNiner is offline
They aren't on the F1, so doubtful on the F2. Check the depth dimensions - that's where you'll likely find the difference.
Old 10-02-2014, 06:10 PM
Cougar54's Avatar
Cougar54
Cougar54 is offline
No, the front and rear drums are not interchangeable. The rear drums are wider (deeper) than the front. The rear drums are no longer reproduced and are not available anywhere that I could find. Check with FrankCowan on this forum as I believe he still has one good used drum left as I bought one from him about 6 weeks ago.
Old 10-02-2014, 07:03 PM
bobj49f2's Avatar
bobj49f2
bobj49f2 is offline
Received 2,120 Likes on 821 Posts
FYI,
Ford changed brake design in the mid 1951 model year, the brake drums are different. Here are the drawings for the earlier models and the later models.
Heritagechris
10-27-2016 07:58 PM
Scotty's 52 F3
02-11-2016 10:46 PM
Cougar54
17
06-20-2015 10:05 PM
Carolina 52
10-12-2012 11:25 PM
Quick Reply: Are the front and rear brake drums interchangeable on 48 f2?
