still getting p0446 code
09-28-2014, 03:51 PM
on
2005 5.4 - code P0446
I just replaced the vapor canister and solenoid. #10 fuse is good. Still getting code. Any ideas?
Thanks
09-29-2014, 03:08 PM
on
Well at least changing the canister seems to have solved the slow fill-ups at the pump. Guess I'll start trying to chase electrical gremlins unless somebody has seen this before and give a me a head start.
09-29-2014, 03:26 PM
Have you checked for operating power on one wire to the CVS and for continuity from the the other wire back to the PCM plug?
09-29-2014, 07:35 PM
on
Have power. I haven't been able to determine for sure which plug and pin is correct to check continuity.
09-29-2014, 08:37 PM
At the CVS, the red/yellow wire is the switched ignition feed. The violet/white wire goes back to pin #61 of PCM connector C175B.
09-30-2014, 03:53 PM
on
Thanks, hopefully I'll have an opportunity to check that in the next couple days.
Two000F250
10-06-2013 12:10 PM
rolltide3006
07-09-2013 10:14 PM
wyobob
1999 to 2016 Super Duty
01-13-2010 08:58 AM
DavisMT
1997-2006 Expedition & Navigator
11-24-2008 07:41 AM
BURNSTOUGHFORD
1997 - 2003 F150
06-25-2008 06:48 AM
