Sponsored by: Real Truck
still getting p0446 code
Old Sep 28, 2014 | 03:51 PM
Villengineer's Avatar
Villengineer
2005 5.4 - code P0446
I just replaced the vapor canister and solenoid. #10 fuse is good. Still getting code. Any ideas?
Thanks
Old Sep 29, 2014 | 03:08 PM
Villengineer
Well at least changing the canister seems to have solved the slow fill-ups at the pump. Guess I'll start trying to chase electrical gremlins unless somebody has seen this before and give a me a head start.
Old Sep 29, 2014 | 03:26 PM
projectSHO89's Avatar
projectSHO89
Have you checked for operating power on one wire to the CVS and for continuity from the the other wire back to the PCM plug?
Old Sep 29, 2014 | 07:35 PM
Villengineer
Have power. I haven't been able to determine for sure which plug and pin is correct to check continuity.
Old Sep 29, 2014 | 08:37 PM
projectSHO89
At the CVS, the red/yellow wire is the switched ignition feed. The violet/white wire goes back to pin #61 of PCM connector C175B.
Old Sep 30, 2014 | 03:53 PM
Villengineer
Thanks, hopefully I'll have an opportunity to check that in the next couple days.
Two000F250
Oct 6, 2013 12:10 PM
rolltide3006
Jul 9, 2013 10:14 PM
wyobob
Jan 13, 2010 08:58 AM
DavisMT
Nov 24, 2008 07:41 AM
BURNSTOUGHFORD
1997 - 2003 F150
Jun 25, 2008 06:48 AM
