The Canadian Vin Info Thread
on
This information have been gathered from chassis and body part catalogs and the master 1948-60 parts catalog. It is accurate to the best of my knowledge.
1948-1952
To facilitate the servicing of vehicles and assist in selecting correct parts for a particular vehicle, an identification numbering system was introduced and recorded on an identification plate on all vehicles produced by Ford Motor Company of Canada, Limited, from the beginning of 1946 models. This identification plate is located on the center of the cowl or dash panel under the hood.
SAMPLE PLATE
Engine - 6G-1829 Model - FH81
Trim - MC-18001
Serial - FH81H48-5001 Paint - M-1722
Explanation of the above plate is as follows:
ENGINE NUMBER
The first digit of this number indicates the model year the engine was originally built, “6” indicates “1946”. The letter in the engine number indicates the piston displacement of the engine, and the type of transmission as follows:
“E” indicates 239 cu. in. piston displacement with 3 speed transmission
“EE” indicates 239 cu. in. piston displacement with heavy duty 3 speed transmission
“J” indicates 239 cu. in. piston displacement with 4 speed transmission
“P” indicates 239 cu. in. piston displacement with 4 speed transmission, passenger camshaft
“G” indicates 239 cu. in. piston displacement with 4 speed transmission, truck camshaft
“Q” indicates 337 cu. in. piston displacement with 5 speed transmission
Engines are also numbered consecutively as they are produced at the factory. This engine number is “1829”, making the complete engine number “6G-1829” which is stamped on the vehicle serial code plate.
TRIM MC-18001
The trim number indicates the type of interior trim in the vehicle. This number denotes a certain colour and type. Therefore is should be quoted on all orders for any replacement trim material.
SERIAL CODE FH81H48-50001
This number is the serial number of the entire vehicle. It indicates the vehicle model type, the branch where the vehicle was built, the model year, and consecutive number of the vehicle as it came off the assembly line.
This serial code consists of five major portions with a secondary breakdown in the first two letters:
Major Portion Breakdown
“FH” - model type 134” W.B. Truck - Ford
“81” - body type chassis and cab
“H” - assembly branch Home Office. “V” would mean Vancouver, etc.
“48” - model year 1948. “49” would be 1949, etc. P is 1952.
“5001” - consecutive job number at assembly plant
(B) Secondary Breakdown
“F” - first letter indicates model designation - Ford
“R” - would designate Mercury
“H” - second letter denotes the wheelbase 134”.
“C” - 110” “D” - 114” “F” - 122”
“M” - 158” “Q” - 176” “U” - 194”
This secondary breakdown is explained further on the next page under the column “Serial Prefix”.
MODEL - FH81
The model number denotes type of model, i.e.
“FH” - 134” wheelbase truck,
“81” - chassis and cab
PAINT - M-1722
M-1722 denotes the colour and type of baking enamel used on the outside of the vehicle and not supplied for repairs. Therefore, it will be necessary to order the corresponding Air Dry enamel for service. A listing of all enamels is included in this catalogue.
NEW MODEL SERIES
In order to simplify the ordering of spare parts, a new model series has been adopted for trucks (effective with 1951 catalogue publication). This new symbol will be used under the “Model” column throughout the body of out truck parts catalogue and eliminates the model series “F47”, “M47”, “F68”, “M68” and wheelbases, etc., used in our previous 1948-9 truck parts catalogues.
The new symbol “C” will now denote 1948, 49, 50 and 51, 1/2 ton 114” wheelbase F-47 and M-47 truck chassis, as described in the following “Model Type” Chart.
<table style="text-align: left; width: 100%;" border="1"><tbody><tr><td colspan="2" rowspan="1">1948-1950 Series</td> <td colspan="2" rowspan="1">1951-1952 Series</td><td>Nominal Rating</td><td>Gross Vehicle Weight</td><td>Wheelbase</td><td colspan="2" rowspan="1">Special Prefix</td></tr><tr><td>Ford</td><td>Mercury</td><td>Ford </td><td>Mercury</td><td></td><td></td><td></td><td>Ford</td><td>Mercury</td></tr><tr><td>F47</td><td>M47</td><td>F1</td><td>M1</td><td>½ ton</td> <td>4700lbs</td><td>114"</td><td>BD</td><td>MD</td></tr><tr><td>F68</td><td>M68</td><td>F3</td><td>M3</td><td>1 ton</td><td>6800lbs</td><td>122”</td><td>DF</td><td>PF</td></tr><tr><td>F105</td><td>M105</td><td>F4</td><td>M4</td><td>1 ½ ton</td><td>10000lbs</td><td>134"</td><td>EH</td><td>QH</td></tr><tr><td>F105</td><td>M105</td><td>F4</td><td>M4</td><td>1 ½ ton</td><td>10000lbs</td><td>158"</td><td>EM</td><td>QM</td></tr><tr><td></td><td><br></td><td>F5</td><td>M5</td><td>2 ton</td><td>14000lbs</td><td>110" C.O.E</td><td>FCW</td><td>RCW</td></tr><tr><td>F135</td><td>M135</td><td>F5</td><td>M5</td><td>2 ton</td><td>14000lbs</td><td>134"</td><td>FH</td><td>RH</td></tr><tr><td></td><td></td><td>F5</td><td>M5</td><td>2 ton</td><td>14000lbs</td><td>134” C.O.E</td><td>FHW</td><td>RHW</td></tr><tr><td>F135</td><td>M135</td><td>F5</td><td>M5</td><td>2 ton</td><td>14000lbs</td><td>158"</td><td>FM</td><td>RM</td></tr><tr><td></td><td></td><td>F5</td><td>M5</td><td>2 ton</td><td>14000lbs</td><td>158” C.O.E</td><td>FMW</td><td>RMW</td></tr><tr><td>F135</td><td>M135</td><td>F5</td><td>M5</td><td>2 ton</td><td>14000lbs</td><td>176"</td><td>FQ</td><td>RQ</td></tr><tr><td></td><td></td><td>F6</td><td>M6</td><td>3 ton</td><td>16000lbs</td><td>110” C.O.E</td><td>GCW</td><td>SCW</td></tr><tr><td>F155</td><td>M155</td><td>F6</td><td>M6</td><td>3 ton</td><td>16000lbs</td><td>134"</td><td>GH</td><td>SH</td></tr><tr><td>F155</td><td>M155</td><td>F6</td><td>M6</td><td>3 ton</td><td>16000lbs</td><td>134” Dump</td><td>GHU</td><td>SHU</td></tr><tr><td></td><td></td><td>F6</td><td>M6</td><td>3 ton</td><td>16000lbs</td><td>134” C.O.E</td><td>GHW</td><td>SHW</td></tr><tr><td>F155</td><td>M155</td><td>F6</td><td>M6</td><td>3 ton</td><td>16000lbs</td><td>158"</td><td>GM</td><td>SM</td></tr><tr><td></td><td></td><td>F6</td><td>M6</td><td>3 ton</td><td>16000lbs</td><td>158” C.O.E</td><td>GMW</td><td>SMW</td></tr><tr><td>F155</td><td>M155</td><td>F6</td><td>M6</td><td>3 ton</td><td>16000lbs</td><td>176"</td><td>GQ</td><td>SQ</td></tr><tr><td>F155</td><td>M155</td><td>F6</td><td>M6</td><td>3 ton</td><td>16000lbs</td><td>194"</td><td>GU</td><td>SU</td></tr><tr><td>F155</td><td>M155</td><td>F6</td><td>M6</td> <td>3 ton</td><td>16000lbs</td><td>194” School Bus</td><td>GUB</td><td>SUB</td></tr><tr><td>F190</td><td>M190</td><td>F7</td><td>M7</td><td>4 ton</td><td>19000lbs</td><td>135"</td><td>HJ</td><td>TJ</td></tr><tr><td>F190</td><td>M190</td><td>F7</td><td>M7</td><td>4 ton</td><td>19000lbs</td><td>147"</td><td>HK</td><td>TK</td></tr><tr><td>F190</td><td>M190</td><td>F7</td><td>M7</td><td>4 ton</td><td>19000lbs</td><td>159"</td><td>HN</td><td>TN</td></tr><tr><td>F190</td><td>M190</td><td>F7</td><td>M7</td><td>4 ton</td><td>19000lbs</td><td>178'"</td><td>HR</td><td>TR</td></tr> <tr> <td>F190</td><td>M190</td><td>F7</td><td>M7</td><td>4 ton</td><td>19000lbs</td><td>195"</td><td>HW</td><td>TW</td></tr><tr><td>F215</td><td>M215</td><td>F8</td><td>M8</td><td>5 ton</td><td>22000lbs</td><td>135"</td><td>JJ</td><td>UJ</td></tr><tr><td>F215</td><td>M215</td><td>F8</td><td>M8</td><td>5 ton</td><td>22000lbs</td><td>147"</td><td>JK</td><td>UK</td></tr><tr><td>F215</td><td>M215</td><td>F8</td><td>M8</td><td>5 ton</td><td>22000lbs</td><td>159"</td><td>JN</td><td>UN</td></tr><tr><td>F215</td><td>M215</td><td>F8</td><td>M8</td><td>5 ton</td><td>22000lbs</td><td>178"</td><td>JR</td><td>UR</td></tr><tr><td>F215</td><td>M215</td><td>F8</td><td>M8</td><td>5 ton</td><td>22000lbs</td><td>195"</td><td>JW</td><td>UW</td></tr></tbody></table>
A third letter is used to denote standard or special units:
A - Standard J - Parcel Delivery
B - Bus U - Dump
D - Diesel W - Cab-over-Engine
A letter follows the body code to denote Standard or DeLuxe cab:
A - Standard B - DeLuxe
Example: GHW81BH51-5001 is a Ford 3 ton 134” W.B. C.O.E. with DeLuxe Cab
GH - shows it is a Ford 3 ton 134” W.B.
W - shows it is a C.O.E.
81B - shows it is a Chassis & DeLuxe Cab
H - shows it is a L.H.D. built at Home Office
51 - shows it is a 1951 model
TRUCK BODY TYPES
Body Type No.
81 - Chassis & Closed Cab Conventional
82 - Panel Delivery (114” Wheelbase)
83 - Pickup (114” Wheelbase)
83 - Express (122” Wheelbase)
84 - Chassis and Cowl
85 - Chassis W/S and Cowl
Here is a listing of all the paint codes for 1948-52. It includes passenger car codes except those that are two toned.
<table style="text-align: left; width: 100%;" border="1"><tbody><tr align="center"><td colspan="4" rowspan="1">Exterior Enamel Paints</td></tr><tr><td>Colour</td><td>Code</td><td>Service Air Dry Number</td><td>Year</td></tr><tr><td>Rotunda Gray</td><td></td><td> M-13220</td><td>1948</td></tr><tr><td>Barcelona Blue</td><td></td><td> M-13221</td><td>1948</td></tr><tr><td>Monsoon Maroon</td><td></td><td> M-13222</td><td>1948</td></tr><tr><td>Aluminum</td><td></td><td>M-3J23</td><td>1951</td></tr><tr><td>Raven Black</td><td>20</td><td>M-2824</td><td>1948-52</td></tr><tr><td>Vermillion Red</td><td>21</td><td>M-2822</td><td>1948-51</td></tr><tr><td>Yosemite Green</td><td>22</td><td>M-1800-A </td><td>1951-52</td></tr><tr><td>Sheffield Green</td><td>23</td><td>M-13517</td><td>1951</td></tr><tr><td>Mission Gray</td><td>24</td><td>M-13514</td><td>1951</td></tr><tr><td>Sportsman Green</td><td>25 or 44</td><td>M-13346</td><td>1950-51</td></tr><tr><td>Sulphur Yellow</td><td>26</td><td>M-13520</td><td>1951</td></tr><tr><td>Fez Red</td><td>27</td><td>M-13290</td><td>1951</td></tr><tr><td>Everglade Green</td><td>28</td><td>M-13325</td><td>1951</td></tr><tr><td>Fanfare Maroon Metallic</td><td>29</td><td>M-1J-2</td><td>1952</td></tr><tr><td>Biscay Blue Metallic</td><td>30</td><td>M-13264</td><td>1949</td></tr><tr><td>Luxor Maroon Metallic</td><td>30</td><td>M-13507</td><td>1951</td></tr><tr><td>Berwick Green Metallic</td><td>31</td> <td>M-13268</td><td>1949</td></tr><tr><td>Starlight Green Metallic</td><td>31</td><td>M-28260-A</td><td>1951</td></tr><tr><td>Banning Blue Metallic</td><td>32</td><td>M-13321</td><td>1951</td></tr><tr><td>Canyon Blue</td><td>33</td><td>M-13284</td><td>1949</td></tr><tr><td>Culver Blue Metallic</td><td>33</td><td>M-13447</td><td>1951</td></tr><tr><td>Newport Grey</td><td>33</td><td>M-13382</td><td>1952</td></tr><tr><td>Birch Grey</td><td>34</td><td>M-13286</td><td>1948-50</td></tr><tr><td>Lucerne Blue</td><td>34</td><td>M-1J-3</td><td>1952</td></tr><tr><td>Sea Mist Green</td><td>35</td><td>M-13282</td><td>1948-50</td></tr><tr><td>Pebble Tan</td><td>35</td><td>M-1J-6</td><td>1952</td></tr><tr><td>Midland Maroon Metallic</td><td>36</td><td>M-13202</td><td>1949</td></tr><tr><td>Meadow Green</td><td>37</td><td>M-13283</td><td>1949</td></tr><tr><td>Coral Flame Red</td><td>37</td><td>M-2822</td><td>1952</td></tr><tr><td>Palisade Green</td><td>38 or 96</td><td> M-13341</td><td>1950</td></tr><tr><td>Forest Green</td><td>39</td><td>M-28209</td><td>1950</td></tr><tr><td>Lakewood Green</td><td>39</td><td>M-1J-73</td><td>1952</td></tr><tr><td>Alpine Blue</td><td>40</td><td>M-28208-A</td><td>1950</td></tr><tr><td>Alpine Blue – Non-metallic</td><td>40</td><td>M-13448</td><td>1951</td></tr><tr><td>Sheridan Blue</td><td>41</td><td>M-13285</td><td>1948-51</td></tr><tr><td>Dover Grey</td><td>42</td><td>M-13344</td><td>1950</td></tr><tr><td>Mirada Yellow</td><td>43</td><td>M-13326</td><td>1950</td></tr><tr><td>Bimini Blue Metallic</td><td>45</td><td>M-13288</td><td>1950</td></tr><tr><td>Cambridge Maroon Metallic</td><td>46</td><td>M-13340</td><td>1950</td></tr><tr><td>Maywood Green Metallic</td><td>47</td><td>M-13322</td><td>1950</td></tr><tr><td>Matador Red Metallic</td><td>48</td><td>M-13347</td><td>1950</td></tr><tr><td>Pacific Blue Metallic</td><td>49</td><td>M-1J-8</td><td>1952</td></tr><tr><td>Cumberland Green Metallic</td><td>50</td><td> M-1J-7</td><td>1952</td></tr><tr><td>Vassar Yellow</td><td>51</td><td>M-1J-1</td><td>1952</td></tr><tr><td>Palisade Green</td><td>96</td><td>M-13341</td><td>1950</td></tr><tr><td>Dover Grey</td><td>98</td><td>M-13344</td><td>1950</td></tr></tbody></table>
1948-1952
SAMPLE PLATE
Trim - MC-18001
ENGINE NUMBER
TRIM MC-18001
MODEL - FH81
PAINT - M-1722
NEW MODEL SERIES
B - Bus U - Dump
TRUCK BODY TYPES
Body Type No.
on
1953-56
Transmission Types
Code Type
3 STD - 3 Speed – standard
3 OD - 3 Speed – overdrive
AUTO - Automatic
3 HD - 3 Speed – heavy duty
4 STD - 4 Speed – standard
5 LD - 5 Speed – light duty
5 MD - 5 Speed – medium duty
5 HD - 5 Speed – heavy duty
5 DD - 5 Speed – direct
5 OD - 5 Speed – overdrive
Trim
Code Description
12 - Tan Genuine Leather
13 - Two-Tone Vinyl (DeLuxe)
14 - Red Vinyl (Standard)
AGA - 1955 - Gray Woven Plastic
AGA - 1956 – Red Vinyl & Gray Plaid Woven Plastic
BGA - 1955 – Gray Vinyl and Red Woven Plastic
BGA - 1956 – Red Vinyl & Black & White Woven Plastic
CGA - 1955 – Gray Vinyl and Green Woven Plastic
CGA - 1956 – Tan Vinyl & Black & White Woven Plastic
Maximum Gross Vehicle Weight – The maximum gross vehicle weight is recorded in this space.
Manufacturing Plant Symbol
H - Windsor
K - Oakville
Model Year
Q - 1953
R - 1954
S - 1955
T - 1956
Rear Axle – The actual ratio of the rear axle is put in this place. Both ratios will be used where two-speed axles are involved.
Body Style
81A - Closed Cab Standard
81B - Closed Cab DeLuxe
82 - Panel Delivery
83 - Pick-up and Express
84 - Open Drive Away
85 - Closed Drive Away
86 - Stake
Truck Serial Prefix
1953-54
FA - F-100 Conventional
MA - M-100 Conventional
FB - F-250 Conventional
MB - M-250 Conventional
FC - F-350 Conventional
MC - M-350 Conventional
FD - F-500 Conventional
MD - M-500 Conventional
FE - F-600 Conventional
ME - M-600 Conventional
FN - F-600 School Bus
MN - M-600 School Bus
FF - F-750 Conventional
MF - M-750 Conventional
FG - F-800 Conventional
MG - M-800 Conventional
FU - F-900 Conventional
MU - M-900 Conventional
1955-56
10 - F-100 Conventional
10 - M-100 Conventional
25 - F-250 Conventional
25 - M-250 Conventional
35 - F-350 Conventional
35 - M-350 Conventional
50 - F-500 Conventional
50 - M-500 Conventional
60 - F-600 Conventional
60 - M-600 Conventional
70 - F-700 Conventional
70 - M-700 Conventional
75 - F-750 Conventional
75 - M-750 Conventional
80 - F-800 Conventional
80 - M-800 Conventional
90 - F-900 Conventional
90 - M-900 Conventional
<table style="text-align: left; width: 100%;" border="1"><tbody><tr align="center"><td Colspan="7" rowspan="1">Model Identification</td> </tr><td colspan="7" rowspan="1">1953</td></tr><tr><td>Series</td><td>Type</td><td>Max G.V.W</td><td>Wheelbase</td><td>Engine</td><td colspan="2" rowspan="1">Serial Prefix</td></tr><tr><td></td><td></td><td></td><td></td><td></td><td>Ford</td><td>Mercury</td></tr><tr><td>F/M-100</td><td>Conventional</td><td>4800lbs</td><td>110"</td><td>8-239</td><td>FAC</td><td>MAC</td></tr><tr><td>F/M-250</td><td>Conventional</td><td>6800lbs</td><td>118"</td><td>8-239</td><td>FBC</td><td>MBC</td></tr><tr><td>F/M-350</td><td>Conventional</td><td>9500lbs</td><td>130"</td><td>8-239</td><td>FCC</td><td>MCC</td></tr><tr><td>F/M-350</td><td>Parcel Delivery</td><td>7800lbs</td><td>104"</td><td>6-215OHV</td><td></td><td></td></tr><tr><td>F/M-350</td><td>Parcel Delivery</td><td>7800lbs</td><td>122"</td><td>6-215OHV</td><td></td><td></td></tr><tr><td>F-500</td><td>Conventional</td><td>14000lbs</td><td>130"</td><td>8-239</td><td>FDC</td><td></td></tr><tr><td>F-500</td><td>Conventional</td><td>14000lbs</td><td>154"</td><td>8-239</td><td>FDH</td><td></td></tr><tr><td>F-500</td><td>School Bus</td><td>12000lbs</td><td>154"</td><td>8-239</td><td></td><td></td></tr><tr><td>F-500</td><td>Cab Over Engine</td><td>14000lbs</td><td>110"</td><td>8-239</td><td></td><td></td></tr><tr><td>F-500</td><td>Cab Over Engine</td><td>14000lbs</td><td>134"</td><td>8-239</td><td></td><td></td></tr><tr><td>F-500</td><td>Cab Over Engine</td><td>14000lbs</td><td>158"</td><td>8-239</td><td></td><td></td></tr><tr><td>M-500</td><td>Conventional</td><td>14000lbs</td><td>130"</td><td>8-255</td><td></td><td>MDC</td></tr><tr><td>M-500</td><td>Conventional</td><td>14000lbs</td><td>154"</td><td>8-255</td><td></td><td>MDH</td></tr><tr><td>M-500</td><td>Cab Over Engine</td><td>14000lbs</td><td>110"</td><td>8-239</td><td></td><td></td></tr><tr><td>M-500</td><td>Cab Over Engine</td><td>14000lbs</td><td>134"</td><td>8-239</td><td></td><td></td></tr><tr><td>M-500</td><td>Cab Over Engine</td><td>14000lbs</td><td>158"</td><td>8-239</td><td></td><td></td></tr><tr><td>F-600</td><td>Conventional</td><td>16000lbs</td><td>130"</td><td>8-239</td><td>FEA</td><td></td></tr><tr><td>F-600</td><td>Conventional</td><td>16000lbs</td><td>154"</td><td>8-239</td><td>FEE</td><td></td></tr><tr><td>F-600</td><td>Conventional</td><td>16000lbs</td><td>172"</td><td>8-239</td><td>FEJ</td><td></td></tr><tr><td>F-600</td><td>School Bus</td><td>16000lbs</td><td>192"</td><td>8-239</td><td>FNB</td><td></td></tr><tr><td>F-600</td><td>Cab Over Engine</td><td>16000lbs</td><td>110"</td><td>8-239</td><td></td><td></td></tr><tr><td>F-600</td><td>Cab Over Engine</td><td>16000lbs</td><td>134"</td><td>8-239</td><td></td><td></td></tr><tr><td>F-600</td><td>Cab Over Engine</td><td>16000lbs</td><td>158"'</td><td>8-239</td><td></td><td></td></tr><tr><td>M-600</td><td>Conventional</td><td>16000lbs</td><td>130"</td><td>8-255</td><td></td><td>MEA</td></tr><tr><td>M-600</td><td>Conventional</td><td>16000lbs</td><td>154"</td><td>8-255</td><td></td><td>MEE</td></tr><tr><td>M-600</td><td>Conventional</td><td>16000lbs</td><td>172"</td><td>8-255</td><td></td><td>MEJ</td></tr><tr><td>M-600</td><td>School Bus</td><td>16000lbs</td><td>192"</td><td>8-255</td><td></td><td>MNB</td></tr><tr><td>M-600</td><td>Cab Over Engine</td><td>16000lbs</td><td>110"</td><td>8-239</td><td></td><td></td></tr><tr><td>M-600</td><td>Cab Over Engine</td><td>16000lbs</td><td>154"</td><td>8-239</td><td></td><td></td></tr><tr><td>M-600</td><td>Cab Over Engine</td><td>16000lbs</td><td>158"</td><td>8-239</td><td></td><td></td></tr><tr><td colspan="7" rowspan="1">1954</td></tr><tr><td>Series</td><td>Type</td><td>Max G.V.W</td><td>Wheelbase</td><td>Engine</td><td colspan="2" rowspan="1">Serial Prefix</td></tr><tr><td></td><td></td><td></td><td></td><td></td><td>Ford</td><td>Mercury</td></tr><tr><td>F/M-100</td><td>Conventional</td><td>4800lbs</td><td>110"</td><td>8-239</td><td>FAE</td><td>MAE</td></tr><tr><td>F/M-250</td><td>Conventional</td><td>6800lbs</td><td>118"</td><td>8-239</td><td>FBE</td><td>MBE</td></tr><tr><td>F/M-350</td><td>Conventional</td><td>9500lbs</td><td>130"</td><td>8-239</td><td>FCE</td><td>MCE</td></tr><tr><td>F/M-350</td><td>Parcel Delivery</td><td>7800lbs</td><td>104"</td><td>6-223OHV</td><td></td><td></td></tr><tr><td>F/M-350</td><td>Parcel Delivery</td><td>7800lbs</td><td>122"</td><td>6-223OHV</td><td></td><td></td></tr><tr><td>F/M-500</td><td>Conventional</td><td>14000lbs</td><td>130"</td><td>8-239</td><td>FDM</td><td>MDM</td></tr><tr><td>F/M-500</td><td>Conventional</td><td>14000lbs</td><td>154'</td><td>8-239</td><td>FDP</td><td>MDP</td></tr><tr><td>F/M-500</td><td>Cab Over Engine</td><td>14000lbs</td><td>110"</td><td>8-239OHV</td><td></td><td></td></tr><tr><td>F/M-500</td><td>Cab Over Engine</td><td>14000lbs</td><td>134"</td><td>8-239OHV</td><td></td><td></td></tr><tr><td>F/M-500</td><td>Cab Over Engine</td><td>14000lbs</td><td>158"</td><td>8-239OHV</td><td></td><td></td></tr><tr><td>F/M-500</td><td>School Bus</td><td>12000lbs</td><td>154"</td><td>8-239OHV</td><td></td><td></td></tr><tr><td>F/M-500</td><td>Parcel Delivery</td><td>14000lbs</td><td>130"</td><td>6-223OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>Conventional</td><td>16000lbs</td><td>130"</td><td>8-255</td><td>FES</td> <td>MES</td></tr><tr><td>F/M-600</td><td>Conventional</td><td>16000lbs</td><td>154"</td><td>8-255</td><td>FDP</td><td>MDP</td></tr><tr><td>F/M-600</td><td>Conventional</td><td>16000lbs</td><td>172"</td><td>8-255</td><td>FDU</td><td>MDU</td></tr><tr><td>F/M-600</td><td>School Bus</td><td>16000lbs</td><td>192"</td><td>8-239OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>School Bus</td><td>16000lbs</td><td>192"</td><td>8-256OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>School Bus</td><td>16000lbs</td><td>210"</td><td>8-239OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>School Bus</td><td>16000lbs</td><td>210"</td><td>8-256OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>Cab Over Engine</td><td>16000lbs</td><td>110"</td><td>8-256OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>Cab Over Engine</td><td>16000lbs</td><td>134"</td><td>8-256OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>Cab Over Engine</td><td>16000lbs</td><td>158"</td><td>8-256OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>Cab Over Engine</td><td>16000lbs</td><td>110"</td><td>8-239OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>Cab Over Engine</td><td>16000lbs</td><td>134"</td><td>8-239OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>Cab Over Engine</td><td>16000lbs</td><td>158"</td><td>8-239OHV</td><td></td><td></td></tr><tr><td colspan="7" rowspan="1">1955</td></tr><tr><td>Series</td><td>Type</td><td>Max G.V.W</td><td>Wheelbase</td><td>Engine</td><td colspan="2" rowspan="1">Serial Prefix</td></tr><tr><td></td><td></td><td></td><td></td><td></td><td>Ford</td><td>Mercury</td></tr><tr><td>F/M-100</td><td>Conventional</td><td>5000lbs</td><td>110"</td><td>8-239OHV</td><td>4</td><td>1</td></tr><tr><td>F/M-250</td><td>Conventional</td><td>6900lbs</td><td>118"</td><td>8-239OHV</td><td>4</td><td>1</td></tr><tr><td>F/M-350</td><td>Conventional</td><td>9500lbs</td><td>130"</td><td>8-239OHV</td><td>4</td><td>1</td></tr><tr><td>F/M-350</td><td>Parcel Delivery</td><td>7800lbs</td><td>104"</td><td>6-223OHV</td><td>4</td><td>1</td></tr><tr><td>F/M-350</td><td>Parcel Delivery</td><td>7800lbs</td><td>122"</td><td>6-223OHV</td><td>4</td><td>1</td></tr><tr><td>F/M-500</td><td>Conventional</td><td>14000lbs</td><td>130"</td><td>8-239OHV</td><td>4</td><td>1</td></tr><tr><td>F/M-500</td><td>Conventional</td><td>14000lbs</td><td>154"</td><td>8-239OHV</td><td>4</td><td>1</td></tr><tr><td>F/M-500</td><td>Cab Over Engine</td><td>14000lbs</td><td>110"</td><td>8-239OHV</td><td></td><td></td></tr><tr><td>F/M-500</td><td>Cab Over Engine</td><td>14000lbs</td><td>134"</td><td>8-239OHV</td><td></td><td></td></tr><tr><td>F/M-500</td><td>Cab Over Engine</td><td>14000lbs</td><td>158"</td><td>8-239OHV</td><td></td><td></td></tr><tr><td>F/M-500</td><td>School Bus</td><td>12000lbs</td><td>154"</td><td>8-239OHV</td><td></td><td></td></tr><tr><td>F/M-500</td><td>Parcel Delivery</td><td>14000lbs</td><td>130"</td><td>6-223OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>Conventional</td><td>16000lbs</td><td>130"</td><td>8-239OHV</td><td>4</td><td>1</td></tr><tr><td>F/M-600</td><td>Conventional</td><td>16000lbs</td><td>130"</td><td>8-256OHV</td><td>4</td><td>1</td></tr><tr><td>F/M-600</td><td>Conventional</td><td>16000lbs</td><td>154"</td><td>8-239OHV</td><td>4</td><td>1</td></tr><tr><td>F/M-600</td><td>Conventional</td><td>16000lbs</td><td>154"</td><td>8-256OHV</td><td>4</td><td>1</td></tr><tr><td>F/M-600</td><td>Conventional</td><td>16000lbs</td><td>172"</td><td>8-239OHV</td><td>4</td><td>1</td></tr><tr><td>F/M-600</td><td>Conventional</td><td>16000lbs</td><td>172"</td><td>8-256OHV</td><td>4</td><td>1</td></tr><tr><td>F/M-600</td><td>School Bus</td><td>16000lbs</td><td>192"</td><td>8-239OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>School Bus</td><td>16000lbs</td><td>192"</td><td>8-256OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>School Bus</td><td>16000lbs</td><td>210"</td><td>8-239OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>School Bus</td><td>16000lbs</td><td>210"</td><td>8-256OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>Cab Over Engine</td><td>16000lbs</td><td>110"</td><td>8-256OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>Cab Over Engine</td><td>16000lbs</td><td>134"</td><td>8-256OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>Cab Over Engine</td><td>16000lbs</td><td>158"</td><td>8-256OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>Cab Over Engine</td><td>16000lbs</td><td>110"</td><td>8-239OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>Cab Over Engine</td><td>16000lbs</td><td>134"</td><td>8-239OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>Cab Over Engine</td><td>16000lbs</td><td>158"</td><td>8-239OHV</td><td></td><td></td></tr><tr><td colspan="7" rowspan="1">1956</td></tr><tr><td>Series</td><td>Type</td><td>Max G.V.W</td><td>Wheelbase</td><td>Engine</td><td></td><td></td></tr><tr><td>F/M-100</td><td>Conventional</td><td>5000lbs</td><td>110"</td><td>8-272OHV</td><td></td><td></td></tr><tr><td>F/M-250</td><td>Conventional</td><td>7400lbs</td><td>118"</td><td>8-272OHV</td><td></td><td></td></tr><tr><td>F/M-350</td><td>Conventional</td><td>9800lbs</td><td>130"</td><td>8-272OHV</td><td></td><td></td></tr><tr><td>F/M-350</td><td>Parcel Delivery</td><td>9800lbs</td><td>104"<br></td><td>6-223OHV</td><td></td><td></td></tr><tr><td>F/M-350</td><td>Parcel Delivery</td><td>9800lbs</td><td>122"</td><td>6-223OHV</td><td></td><td></td></tr><tr><td>F/M-500</td><td>Conventional</td><td>15000lbs</td><td>130"</td><td>8-272OHV</td><td></td><td></td></tr><tr><td>F/M-500</td><td>Conventional</td><td>15000lbs</td><td>154"</td><td>8-272OHV</td><td></td><td></td></tr><tr><td>F/M-500</td><td>Cab Over Engine</td><td>15000lbs</td><td>110"</td><td>8-272OHV</td><td></td><td></td></tr><tr><td>F/M-500</td><td>Cab Over Engine</td><td>15000lbs</td><td>134"</td><td>8-272OHV</td><td></td><td></td></tr><tr><td>F/M-500</td><td>Cab Over Engine</td><td>15000lbs</td><td>158"</td><td>8-272OHV</td><td></td><td></td></tr><tr><td>F/M-500</td><td>School Bus</td><td>13000lbs</td><td>154"</td><td>8-272OHV</td><td></td><td></td></tr><tr><td>F/M-500</td><td>Parcel Delivery</td><td>15000lbs</td><td>130"</td><td>6-223OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>Conventional</td><td>18000lbs</td><td>130"</td><td>8-272OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>Conventional</td><td>18000lbs</td><td>154"</td><td>8-272OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>Conventional</td><td>18000lbs</td><td>172"</td><td>8-272OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>School Bus</td><td>18000lbs</td><td>192"</td><td>8-272OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>School Bus</td><td>18000lbs</td><td>210"</td><td>8-272OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>Cab Over Engine</td><td>18000lbs</td><td>110"</td><td>8-272OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>Cab Over Engine</td><td>18000lbs</td><td>134"</td><td>8-272OHV</td><td></td><td></td></tr><tr><td>F/M-600</td><td>Cab Over Engine</td><td>18000lbs</td><td>158"</td><td>8-272OHV</td><td></td><td></td></tr></tbody></table>
Here is a listing of all the paint codes for 1953-56. It includes 1953-54 passenger car codes except those that are two toned.
<table style="text-align: left; width: 100%;" border="1"><tbody><tr align="center"><td colspan="4" rowspan="1">Exterior Enamel Paints</td></tr><tr><td>Colour</td><td>Code</td><td>Service Air Dry Number</td><td>Year</td></tr><tr><td>Alaska White</td><td>01</td><td>M-25J-291-SE </td><td>1955</td></tr><tr><td>Colonial White</td><td>01</td><td>M-20J-524-SE</td><td>1956</td></tr><tr><td>Diamond Blue</td><td>02</td><td>M-20J-523-SE</td><td>1956</td></tr><tr><td>Gulfstream Blue Metallic</td><td>03</td><td>M-25J-318-SE</td><td>1955</td></tr><tr><td>Waterfall Blue</td><td>04</td><td>M-20J-355-SE</td><td>1955</td></tr><tr><td>Nocturne Blue</td><td>04</td><td>M-20J-521-SE</td><td>1956</td></tr><tr><td>Meadow Mist Green</td><td>06</td><td>M-20J-527-SE</td><td>1956</td></tr><tr><td>Goldenrod Yellow</td><td>07</td><td>M-20J-358-SE</td><td>1955</td></tr><tr><td>Carousel Red</td><td>09</td><td>M-25J-427-SE</td><td>1956</td></tr><tr><td>Atlantic Blue Metallic</td><td>10</td><td>M-25J-227-SE</td><td>1954</td></tr><tr><td>Raven Black</td><td>10</td><td>M-20J-1724-SE</td><td>1956</td></tr><tr><td>Bloomfield Green Metallic</td><td>11</td><td>M-25J-233-SE</td><td>1954</td></tr><tr><td>Mohawk Maroon Metallic</td><td>12</td><td>M-25J-190-SE</td><td>1954</td></tr><tr><td>Sandlewood Tan</td><td>13</td><td>M-20J-261-SE</td><td>1954</td></tr><tr><td>Springfield Green</td><td>13</td><td>M-25J-175-SE</td><td>1955</td></tr><tr><td>Saffron Yellow</td><td>13</td><td>M-25J-438-SE</td><td>1956</td></tr><tr><td>Brentwood Brown Metallic</td><td>14</td><td>M-25J-191-SE</td><td>1954</td></tr><tr><td>Sandstone White</td><td>15</td><td>M-20J-273-SE</td><td>1954</td></tr><tr><td>Siren Red</td><td>16</td><td>M-25J-218-SE</td><td>1954</td></tr><tr><td>Platinum Grey</td><td>16</td><td>M-20J-532-SE</td><td>1956</td></tr><tr><td>Lakewood Green</td><td>17</td><td>M-2J-73-SE</td><td>1954</td></tr><tr><td>India Black/Raven Black</td><td>20</td><td>M-25J-1724-SE</td><td>1953-55</td></tr><tr><td>Bittersweet</td><td>21</td><td>M-25J-197-SE</td><td>1954</td></tr><tr><td>Yosemite Green</td><td>22</td><td>M-1800-A</td><td>1953-54</td></tr><tr><td>Torch Red</td><td>22</td><td>M-20J-175-SE</td><td>1955</td></tr><tr><td>Parklane Green</td><td>23</td><td>M-25J-296-SE</td><td>1954</td></tr><tr><td>Lakeland Blue</td><td>24</td><td>M-25J-304-SE</td><td>1954</td></tr><tr><td>Meadow Green</td><td>26</td><td>M-14283</td><td>1955</td></tr><tr><td>Meadow Green</td><td>27</td><td>M-14283</td><td>1956</td></tr><tr><td>Killarney Green</td><td>28</td><td>M-20J-257-SE</td><td>1956</td></tr><tr><td>Cadet Blue Metallic</td><td>33</td><td>M-20J-253-SE</td><td>1954</td></tr><tr><td>Coral Flame</td><td>37</td><td>M-2822</td><td>1953-54</td></tr><tr><td>Superior Blue Metallic</td><td>38</td><td>M-25J-189-SE</td><td>1953</td></tr><tr><td>Banff Blue</td><td>39</td><td>M-25J-212-SE</td><td>1953</td></tr><tr><td>Glenwood Gray</td><td>40</td><td>M-25J-14382-SE</td><td>1953</td></tr><tr><td>Sheridan Blue</td><td>41</td><td>M-13285</td><td>1954</td></tr><tr><td>Tahiti Tan</td><td>43</td><td>M-25J-192-SE</td><td>1953</td></tr><tr><td>Mohawk Maroon Metallic</td><td>44</td><td>M-25J-190-SE</td><td>1953</td></tr><tr><td>Sherwood Green Metallic</td><td>45</td><td>M-25J-199-SE</td><td>1953</td></tr><tr><td>Village Green Metallic</td><td>46</td><td>M-25J-213-SE</td><td>1953</td></tr><tr><td>Cavalier Yellow</td><td>47</td><td>M-25J-1-SE</td><td>1953-54</td></tr></tbody></table>
Transmission Types
Code Type
AUTO - Automatic
Trim
Code Description
H - Windsor
K - Oakville
Model Year
Q - 1953
R - 1954
S - 1955
T - 1956
Body Style
82 - Panel Delivery
86 - Stake
Truck Serial Prefix
1953-54
1955-56
Wow, Nathan, you've compiled an outstanding reference. Interests me to see the differences between US and Canadian specs. As I'd understood, there was no Canadian F-2, and the F-3 was called a one ton north of the border. The F-4 was the one ton in the US, but in Canada it was a 1.5 ton. And I learn the F-4 could be either a 134" or 158" spec., as opposed to the US having only a 134". I've bookmarked your thread, and reps given. Thx. Stu
on
Thanks, hopefully it will help someone out. It took darn near forever to format a html table into a format that vbulletin will display correctly.
Stu, did the US F-5/F-6 get the 176" and 194" wheelbases? The Canadian ones with those wheelbases were standard equipped with the wide fenders/front axle.
I've always been curious about this "option" for 1951-52 F/M-3 trucks:
Its only mentioned in my 1952 supplementary catalog. It is a Timken axle. Uses 8 bolt front wheels from an F-2 and has 16" 6 bolt dually wheels in the rear. I assume the same bolt pattern as 1953-66 trucks. The wheels do have a different part number from the 1953-56 wheels.
I have a '52 Full Product Line brochure that shows the F-5 and F-6 available with 134", 158", and 176" wheelbase on conventional cab trucks. The F-5 school bus had a 158" chassis, and the F-6 had the 194". No other mention of the 194".
Your supplement reference is amazing! A DRW option on F/M-3s using a different rear axle. Can you tell from the Chassis Catalog if it was the Timken A150 as used in the '53 F-250 or the B150 as used under the F-350? From the cross section diagram the wheels have the same Firestone "RHP" outer rims as were supplied on F-350s beginning in'53. Stu
on
As far as I can tell it is a Timken 51524. The Timken A150 and B150 use different wheel bearings and axle shafts.
Some of the part numbers from the diagram are in the master catalog but there is no main listing.
This is what I can figure out:
Used 51-52
14" and 12" drums are listed
Used the same axle shaft as the regular pickup
12 - 9/16 18 right hand thread studs per vehicle with 7/8 nuts
16" 6.50 tires all around. Single wheels on front and spare.
Its just been a curiosity to me. Kind of gave me the idea for my DRW pickup. A bit of a precedent you could say
Used 51-52
Hi there.
I'm a newbie and not sure if this is the right place to post this.
I have a bus here in New Zealand on a 1948 Mercury chassis. The Serial Number Code I have is C84BFS 9G22728F. I'm trying to find out as much info as I can on this chassis and your help would be really appreciated. Thanks, Phil
on
Your chassis was most likely built by Ford of Canada but no one is really sure if they were assigned a vin by Ford of Canada or Ford of New Zealand/Australia. Of the few that have posted here have had trucks completely stripped of all identification.
Is your serial number on a plate by Ford or by the builder of the bus body? If its by the bus builder it might be a number assigned by them.
on
The body part catalog books don't differentiate between car and truck with the paint codes. I figured it was easier to just list them all rather than miss one that was for a truck. Maybe someone with a Canadian car might stumble across this thread and be like, that's my paint colour! I'd hate to restore one of the cars to 100% original as there are like 50 different exterior/interior trim codes per year.
I have a vin plate from a 1948 Mercury M68 with a paint code - special.
