Which fan shroud for super cool rad. in highboy?
Working on a '72 F-250 4x4 that has a 460 swapped in and now has a super cooling radiator. Now I need a fan shroud but there is more than one option.
1st option: Fan Shroud, Super Cooling-Broncograveyard.com
This one shows truck application is '77 & up which had a different type of super cool rad (different mounting flanges. not sure if this one will work.
2nd option: Fan Shroud | Dennis Carpenter Ford Restoration Parts
This one roughly covers the core size of the super cool rad.
3rd option: Fan Shroud | Dennis Carpenter Ford Restoration Parts
This one also roughly covers the core size of the super cool.
Which one do I need? Might there be another one available that I have not listed?
Any help/info would be much appreciated.
1967/72 F100/350: Be aware that the radiator support is different with the Super Cooling Radiator...as it has a larger opening radius.
2nd option: Fan Shroud | Dennis Carpenter Ford Restoration Parts =
1967 F100/350 352 / 1968/76 F100/350 360/390 / Regardless of what Carpenter claims, was not used on any 1977/79, was not used with 460.
Super Cooling Radiator: 26 1/4" wide x 24 1/4" high / Has a HUGE top tank that is wider and deeper than the Standard/Xtra Cooling & A/C Radiators.
1973/74 F100/350 460 may or may not have the Super Cooling Radiator, but all 1975/79 F100/350 460's do.
columbia1spring
08-12-2017 06:49 PM
gdirwin
01-12-2015 07:47 PM
