Ongoing quest for gas mileage...
I posted this in the 1980-1986 forum and thought some here might be interested.
https://www.ford-trucks.com/forums/1...-9l-300-a.html
Bed cover gained me at least 1.5 mpg. Looks pretty sweet too. Don't quote me here but from my understanding increasing the rear wheel pressure essentially increases the tire diameter. Which will increase mpg but will show a decrease in your stats due to a slightly off odometer. Not sure if 2 to 3 lbs of extra pressure is enough to throw it off much but that is what a much wiser gear head explained to me. I do say with certainty , yes to the bedcover. I have also thought about somehow eliminating the parachutes under the body/ rear wheel wells / bumper, with dams or leveling the transitions with sheet aluminum or some other rigid material. In an effort to decrease under body drag. I think it can be done without being noticeable from eye level without looking like an eco-modder. Been threatening to try this for years.
Here's a funny thing, proving that intuition doesn't always translate to real-life improvements (nor do ostensibly-"scientific" software programs, for that matter). Some testing outfit, and I think it might have been Consumer Reports, tested fuel consumption of various models of pickup trucks, first with the tailgate up (and no bed-cover), then with the tailgate down, which is popularly thought to improve mpg. Well, some trucks did a little better with the tailgate up, some did so with it down, and some showed no significant difference either way, and it was impossible to predict which would do which, lacking a wind-tunnel. This was done maybe ten or so years ago, IIRC.
Here's another example: Way back in the days of the Mobilgas Economy Run, we learned that the pro and semi-pro teams that took part in the Run always pumped the tire pressure way up. Ah, but sometimes that made things worse! What they found happening was that the hard, skinny, over-inflated tires could sometimes vibrate the carburetor float in such a way that the float needle got to bouncing open and closed, raising the fuel level in the bowl at least enough to richen the mixture and sometimes enough to spill over. Well dang!!
And the trouble is that for any ordinary vehicle owner to set up accurate, repeatable road-tests is not at all easy. Having good instrumentation, such as a fuel flowmeter and a relative air density meter and correction table, would help a lot.
robr0924
09-08-2005 10:12 PM
