steering damper/resistor question
Hi guys,
I'm working on Luci's steering shaft and need to know how close to the headrr is too close for one of the newer style steering dampers? As it stands now, I have about 3.5 inches between the end of the column and the header. I would like to attach the damper/ujoint to the column but that will put me about 1.5 inches from the header.
Any thoughts?
Any thoughts?
Maybe it's just me, but I don't like those things. I eliminated one when I replaced the column. Never had any vibration in the steering. I think with the new power steering units they aren't necessary (IMO). Just seems like a weak point.
They do make a new style damper, all steel. But again, I've never felt the need.
As far as heat from the header, I guess it depends on what the dampen material is made of. Will it burn or melt?
Some how, I remembered to take pictures!!
Mii after market front end w/power rack (mid 80s T-Bird)
32" CPP column (sketchy quality)
3.5" drop hanger
302 w/BBK long tube
Borgeson 1" DD > 3/4 DD steering damper
Flaming River 3/4 DD > 3/4 DD u-joint
Borgeson 3/4- 36 > 3/4 DD u-joint
3/4 steering shaft support
3.5" drop hanger
302 w/BBK long tube
kevintoupin
16
06-22-2017 04:30 PM
IDIDieselJohn
07-14-2009 05:47 PM
chadwickma
11-09-2006 09:40 AM
