Water pump direction
Old 09-14-2014, 08:25 PM
silar's Avatar
silar
silar is offline
Really dumb question...
I'm currently looking at alternate ways of running my belts in my 1982 F100 with 302 and I noticed that some people have their belts on where the water pump goes clockwise (looking at it in the front), and some have theirs going counter-clockwise.
Are there 2 different types of water pumps or do they mysteriously work both ways? (I told you... dumb question)...
Old 09-14-2014, 09:01 PM
silar's Avatar
silar
silar is offline
Once again.. Apparently I didn't search. Please ignore this thread..
Old 09-15-2014, 03:50 AM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is offline
Well since you figured out yourself, you probably found out about the newer engines using a single serpentine belt that drives the water pump in reverse. The older V belts turn the water pump clockwise. And there are two different types of pumps, each optimized for each direction. And the front covers have to match as well.
Old 09-15-2014, 11:31 AM
silar's Avatar
silar
silar is offline
I did.. Thanks!
Old 09-16-2014, 11:52 AM
baddad457's Avatar
baddad457
baddad457 is offline
That's not completely true. The 79-85 Stangs used a reverse pump on a std rotation timing cover.
Old 09-16-2014, 11:58 AM
David7.3's Avatar
David7.3
David7.3 is offline
But they corrected that problem, realizing that problem, It would cavitate at high temps, and with pressure in the system, you would always have to bleed the system when it was hot out with the a/c running.
Old 09-16-2014, 01:22 PM
baddad457's Avatar
baddad457
Never said it worked good, only that they DID use a reverse pump on a std cover.
Old 09-16-2014, 01:27 PM
David7.3's Avatar
David7.3
David7.3 is offline
I gotcha just bust'n ba**s
money pit 69
Engine Swaps
11-27-2014 08:20 PM
cyris426
03-31-2014 08:09 AM
iditurbo54
06-14-2012 08:12 PM
BuckHammer
135
06-09-2012 11:35 AM
Quick Reply: Water pump direction
