Turbo. Replace or rebuild
Old 09-11-2014, 09:18 AM
dmueller71's Avatar
dmueller71
dmueller71 is offline
Well, when it rains it pours I guess. It seems like the metals that were in my last OA where from the turbo bearing going. I got the dreaded squeal today. So, do I rebuild or replace? After my HPOP fiasco, money is tight, but I don't want to attempt to rebuild it and having never done it, screw something up. I see quite a few on Ebay for $400 or less, so I'm torn.
Opinions???
Old 09-11-2014, 09:34 AM
ToMang07's Avatar
ToMang07
ToMang07 is online now
Opinions???
IMO rebuild it, or pay a shop to do it if you're not capable. I wouldn't risk a sight-unseen turbo off fleabay, God only knows what you'd get.
Old 09-11-2014, 11:07 AM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
$150+shipping? got an extra one off a member here that i rebuilt, chasing a sound. So, it has about 2hrs on it since i removed it to install the one with the ww in it....pm if interested
Old 09-11-2014, 11:16 AM
JOHN2001's Avatar
JOHN2001
JOHN2001 is offline
Nice to see my old turbo making it's way around
Old 09-11-2014, 11:19 AM
timmyboy76's Avatar
timmyboy76
haha....its been a great back up for the, roadtrips and/or buddy's, if needed...went to the river with me last weekend for a bachelor party...
Old 09-11-2014, 08:31 PM
Punisher29073's Avatar
Punisher29073
Punisher29073 is offline
Should I rebuild mine if it isn't doing anything bad yet? I have everything in front of it off. It has about 190k mi on it. I am tempted to go ahead and rebuild while I am there.
Ryan
Old 09-11-2014, 08:50 PM
carl2591's Avatar
carl2591
carl2591 is offline
now this is a timly thread for sure.
I hear, or suppose i hear, a very high pitch squeal when driving my 2003 SD with 168K miles. I can hear the turbo under acceleration, which is stock FAIK (far as i know) but i also hear what sounds like a high pitch noise as well.
I was wonder at what miles do turbo usually need to be rebuilt.
Now i do know some of the history. The original owner did pull a 25ft dual axle boat at times and he had the truck from 50K to 108K. The second owner pulled a smaller boat and his son pulled a landscape trailer at times but not every day and the trailer was only some 3-4K more or less.
The 2nd owner got at 108 and sold to me at 168K miles.. No tunes, mods etc at all.
SO what is a good mileage number to use for turbo rebuild. I was going to do a full rebuild including the EBPV mods as i want to get a tuner that will use that for exhaust brake function.
the 360 bearing, a new WW, not ww2, all the orings etc.
Old 09-11-2014, 09:01 PM
JOHN2001's Avatar
JOHN2001
JOHN2001 is offline
Side to side play is fine as long as it's not hitting the housing. In and out play is BAD and it needs to be rebuilt.
Old 09-12-2014, 10:57 AM
lartross's Avatar
lartross
lartross is offline
Ryan, I rebuilt mine with only 120000 miles when I did my uppipes just because I was there. It's cheap and easy for piece of mind.
Old 09-12-2014, 11:16 AM
KJNDIVER's Avatar
KJNDIVER
KJNDIVER is offline
I rebuilt mine when it was just shy of 300k. I did the ww2 and a better wastegate controller. I had a few hiccups during the job, but i couldnt be more pleased with the results. In hindsight, the only thing i would do different is the 360 bearing. Read about it here.
Old 09-15-2014, 08:32 AM
carl2591's Avatar
carl2591
carl2591 is offline
I was looking online and saw a new turbo for 7.3L on ebay. In looking at the pictures i see two valves on the exhaust side turbine.
There is a valve on the top or side with split pipe side which i believe sits on the top of the "up pipes" that has the large diaphragm type valve with rod attached to intake side on top , what is that valve for. ??
also i see another valve on the bottom of the turbo and not sure what controls that valve and what is its function.
sorry to sound so confused but i am to a point on turbos it seems.
Old 09-15-2014, 08:54 AM
JOHN2001's Avatar
JOHN2001
JOHN2001 is offline
Sounds like you're seeing the waste gate for the one at the top. On the bottom most likely is the exhaust back pressure valve... It's also been awhile since I've looked at one too.
'94IDITurbo7.3
05-15-2015 09:41 PM
lartross
09-16-2013 03:26 PM
rodneywar
06-05-2012 06:00 PM
baby2000
03-19-2009 02:32 PM
mblanken881
01-28-2009 12:15 PM
Quick Reply: Turbo. Replace or rebuild
