Gurus-- "Hop-up" AC?
Old 09-09-2014, 02:23 PM
Im50fast's Avatar
Im50fast
Im50fast is offline
I should have mentioned: I am going to my friends work tomorrow to rebuild my calipers and bleed the brakes and balance the tires- so yes I will have access to the refrigerant evac and fill machine.
But I don't have a clue where to find the orifice tube.
Old 09-09-2014, 03:43 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
It is just before the evaporator core.
Old 09-09-2014, 04:29 PM
Im50fast's Avatar
Im50fast
Im50fast is offline
Nice! Thank you Mr. Kovalsky. But now you have me concerned about getting the wrong part-what do you recommend specifically for looking it up and getting the right part and where to get it?
I've never bought parts for air conditioning before. Should I just go to advance or AutoZone? Or is this a situation where a Ford dealer part would be best?
Old 09-09-2014, 04:48 PM
maples01's Avatar
maples01
maples01 is offline
I kind off miss my meat locker, been driving the 73 Econoline, none of that fancy stuff like AC, power steering/brakes, has the manual drums on it, but less parts means it keeps going without bleeding me dry. Just wait till your vacuum canister starts failing, AC goes to default, thats defroster in the front, and heat in the rear, yep, heater in the rear, and this fiasco is all because of a $4 part, but requires either $1700 dealer repair, have to remove the entire front system to access it, of a creative owner to relocate the lines and install a vacuum canister in an accessible location.
Old 09-09-2014, 05:50 PM
tx2sturgis's Avatar
tx2sturgis
tx2sturgis is offline
Wink
Originally Posted by k9dr
Hmmmmmmm. E-fans and louvers. Getting interesting.
However, in order to take a saw to the hood of my gorgeous SeaFoam Beast I would have to:
1) Get drunk first to dull the pain
2) Have someone else do it and come back when the violence was over.
k9dr
Both are very do-able.
Old 09-09-2014, 05:53 PM
tx2sturgis's Avatar
tx2sturgis
Thumbs up its only metal
Originally Posted by JWA
I'm with ya on NOT cutting into the hood et al---that's a bit extreme IMHO. I'm sure such mods have a place but not in this case.
Hey, he asked for hop-ups....he never said no grinding or cutting.
Old 09-09-2014, 06:55 PM
Mark Kovalsky
I don't know if they know the right one or not. I used an AC parts house. They only sold AC parts. They also had a listing for the right part for every AC system. You can try the parts stores, they may have the right one.
Old 09-09-2014, 08:00 PM
maples01's Avatar
maples01
maples01 is offline
The hood is a fiberglass type material, I'd not cut one, it crumbles, or at least mine does, you cant bolt or screw to it, the bug deflector I had bought was glued and screwed, the surface had been thoroughly cleaned prior, it came loose, I used larger screws, deeper threads, acetone cleaned and secured, it came loose, I later put inserts in it, it came loose, so I threw it away, I'd look for a metal hood before considering moding.
Old 09-09-2014, 09:14 PM
YoGeorge's Avatar
YoGeorge
YoGeorge is offline
My '02 has a plastic hood. I love it--the van is white and given the amount of paint chips it has, I am truly glad that I don't have a ton of rusty spots. Or worse yet, rust in the front seam.... The alum hoods on Explorers had problems with bubbling paint as well (I was looking at used ones a while back).
George
0gers
1997-2006 Expedition & Navigator
30
10-05-2011 04:05 PM
Dave the Brewer
07-18-2005 03:55 PM
onetonfan
09-25-2004 05:58 PM
Menudo
09-07-2003 07:36 PM
Quick Reply: Gurus-- "Hop-up" AC?
