6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Average life expectancy of a stock 6.4L?
Old 09-11-2014, 12:58 PM
parkland's Avatar
parkland
parkland is offline
From what I've seen, 6.4 trucks that get worked hard and driven on the highway lots seem to last just fine. Seen a few that are way up there in mileage, no major problems.
It's the trucks that people use as personal chariots to cruise around town, and galavant. usually develop major issues from the emissions junk.
Old 09-12-2014, 10:09 AM
RM2738's Avatar
RM2738
RM2738 is offline
What's the average you've seen on high mileage 6.4's?
I periodically check the private market and can only find trucks with ~250,000. I saw ONE recovery truck with 400,000 but Oasis said it had two or three fuel pumps, radiators, and a TON of repairs.
Old 09-14-2014, 02:04 PM
parkland's Avatar
parkland
parkland is offline
That sounds about normal, from what I've seen. The 6.4 pumps last about 200,000 to 300,000 km's, but on the bright side, usually it's just the pump that needs replacing. This isn't a bad thing, chev 6.5 diesels don't make it that long, and the pumps aren't much cheaper.
Mechanical pumps don't last longer, they just keep running when they fall way out of spec, thats my opinion.
Old 09-14-2014, 06:28 PM
RM2738's Avatar
RM2738
RM2738 is offline
Would it be almost safe to say that the fuel pump might be a "wear and tear" item and one may consider replacing the pump at say.... 200,000-250,000 miles as preventative maintenance?
Old 09-14-2014, 06:42 PM
bubbasz1's Avatar
bubbasz1
bubbasz1 is offline
I would say that's pretty reasonable, I wonder what they see as far as durability on the Maxxforce7, basically the same motor.
Old 09-14-2014, 08:48 PM
parkland's Avatar
parkland
parkland is offline
I don't know about that, they could go longer or fail sooner. The real delimna is that when it craps the bed, you have an undrivable truck, where older engines would just run rough.
Old 09-14-2014, 08:51 PM
parkland's Avatar
parkland
parkland is offline
Same issue as the ford version, oil dilution.
Overall, the 6.4 / maxxforce 7 is an awesome motor, but the emission system is hard on it.
kjeffery
06-18-2018 09:36 PM
mandog888
04-13-2015 11:05 AM
Country_boy_2007
15
03-21-2014 06:54 PM
Aune163rd
25
05-22-2011 07:52 PM
prenticect
32
06-07-2008 05:55 PM
Quick Reply: Average life expectancy of a stock 6.4L?
