Cab Replacement
Old 09-11-2014, 04:06 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Originally Posted by Reziac
It does? What about the one bolted to the engine block, or the door?
<blink></blink>
There is NO vin on the engine.
And the door is just a sticker.
There is a Partial vin on the passenger frame rail as well, but the like I said, the vin follows the cab
Old 09-11-2014, 05:37 PM
Eddiec1564's Avatar
Eddiec1564
Eddiec1564 is offline
On a 1990 cab I did find a "dog tag" on the driver's side nearby the brake booster, was held in place with just a metal screw. On that same frame I found two vin numbers on the pass side frame rail. One was under the AC box and the other was just under the cab end next to the bed/cab parting.
Just do not mess up the VIN tag rivets, remount it and throw about twenty years of crud on top of it!
Old 09-11-2014, 07:00 PM
Reziac's Avatar
Reziac
Reziac is offline
I've seen metal VIN plates on the door. And my old truck had one riveted to the block. When the engine was rebuilt we replaced the block, and the mechanic pried it off and handed it to me. I think it's still in the glove box.
Old 09-11-2014, 07:03 PM
Diesel_Brad
Bull hockey.
Ford has not used rivet on vin tags in the doors since 79
Also, BS on the vin tag on the block. NEVER HAPPENED. There is a SERIES number though that is stamped or cast into the block to give an approximate date it was made
Old 09-11-2014, 07:48 PM
Reziac's Avatar
Reziac
Reziac is offline
Well then, you're in luck! my old truck is a 1978.
Old 09-12-2014, 05:00 AM
Diesel_Brad
In case you didn't notice... We are in a 87-96 forum
Old 09-12-2014, 07:25 AM
Reziac's Avatar
Reziac
Reziac is offline
And I'd wandered in cuz I also have a 1991 F350 dually that's the other love of my life, but hadn't got round to braggin' on it yet.
http://home.earthlink.net/~rividh/truck/100_0985_sm.jpg
Old 09-12-2014, 02:06 PM
Diesel_Brad
And again ford NEVER put Vin numbers on the engine, EVER
Old 09-12-2014, 02:13 PM
Crewcabber's Avatar
Crewcabber
Crewcabber is offline
I want to say back in the 40's the truck numbers matched frame cab engine and trans.
Old 09-12-2014, 02:23 PM
Diesel_Brad
I would like to see that.
Old 09-12-2014, 02:31 PM
Crewcabber's Avatar
Crewcabber
lol Ill snap some pictures for you. Oh wait it doesn't have the original motor So that's a no go.
Old 09-12-2014, 04:31 PM
Diesel_Brad
I googled it and the closest thing to a vin on the engine is on the frame and the body. Nothing about it on the engine
  #28
Old 09-12-2014, 08:22 PM
GNR22's Avatar
GNR22
GNR22 is offline
Fabri-cobbler
Just to be clear, you should NOT grind the backside of the rivets on the underside of the dash off being careful to make the top side of the VIN plate remain untouched. And you should NOT JB Weld your original VIN in place of the new cabs VIN. That would be illegal and it would also look like it never happened.
  #29
Old 09-13-2014, 06:22 AM
Diesel_Brad
Or using black rivets to replace the originals. LOL
  #30
Old 09-13-2014, 11:39 AM
cghkuyk's Avatar
cghkuyk
cghkuyk is offline
Yes and buddies to help...
Quick Reply: Cab Replacement
