A Pickup Car Find for $3,000 Bucks!
Old 09-02-2014, 08:07 PM
edtahaney's Avatar
edtahaney
edtahaney is offline
FTE Editor
Thumbs up A Pickup Car Find for $3,000 Bucks!
Check out this 1972 Ranchero find here:
A Pickup Car Find for $3,000 Bucks! | Ford Trucks
Any advice on how to fix the a/c would be much appreciated!
Old 09-02-2014, 08:43 PM
SVTF150AZ's Avatar
SVTF150AZ
SVTF150AZ is offline
The a/c system is the same on all Ford intermediates from '72-'79, including Thunderbird & Cougar. You should be able to locate a suitable donor car in a wrecking yard or online. I might suggest you do not use the factory compressor, but instead retro fit a modern unit such as a Sanden. And, by all means, do a proper R-134a conversion also. I hope this helps, good luck!
Old 09-02-2014, 10:16 PM
impish's Avatar
impish
impish is offline
Indeed, it does! Regarding the compressor, I actually expect to use a modern axial piston type. Here's the engine going in this white beast:
It's brand-new, one of 6 I bought back in 1996 or '7, Mustang eng. production over-run, everything seen on it, including plugs, wires, harness, injectors, fuel rail, intake manifolds, throttle body, water pump, flywheel, clutch assembly, bell housing, (stainless exh. headers were cannibalized!), all for $2195! A pain will be finding original front-end bracketry, as I plan to go serpentine. I'll take a few pics tomorrow of the unusual way the connections are made at the evaporator core box, underhood. The nearest bone-yard is unfortunately 35 miles away.....
Hope I'm not getting to wordy and boring! impish
Nickk97tml
Garage & Workshop
18
03-03-2014 02:11 PM
FordHubby
Escape & Escape Hybrid
08-06-2011 07:17 AM
daddio360
General Automotive Discussion
11-30-2008 07:14 PM
spencry25
07-11-2003 10:41 PM
zimman20
Garage & Workshop
10-18-2002 01:11 PM
Quick Reply: A Pickup Car Find for $3,000 Bucks!
