Hit trany coolan line with sawzall, patched it now tranny hesitating and slipping. HE
Just like the title says, putting the stack on. 210k single cab 4x4 1995 f350 no mods. Tranny had no problems prior. Hesitates going into drive and reverse. Slips in first. How screwed am I? I cut out the hole in the hard line and patched it with some heavy duty hose that was a little bigger than the line and clamped it tight. If there's a way to add pictures please let me know. Drove about 6 miles with the hole until someone at the red light told me I was pissing trany fluid. What do you guys think?
Not trying to be a jerk or smart a$$, but just to rule out the obvious, did you get the level back to where it's suppose to be?
OD off light flashing means the trans has thrown a code, if you don't think you cut any wires or anything, you need to find a shop that can pull the code for you. Not every scanner can "talk" to our trucks, so if you can find someone who specializes in powerstrokes.
EDIT: or a reputable transmission shop. Also if you filled it did you use the proper fluid?
Your truck doesn't have a tow/haul light. It does have an OD OFF light. When that light is flashing it means something is wrong with the transmission. High temperature is only one of about 50 reasons that the OD OFF light would flash.
When you checked the ATF level was the transmission warmed up, in park, and the engine running?
caedo
07-31-2013 03:58 PM
rtazz17
10-28-2009 06:08 PM
jrandalls
03-26-2008 05:25 PM
Marc150
02-25-2008 10:46 AM
