The long search has ended, new truck in hand.
For years I have been waiting for the right opportunity to present itself for an affordable, clean OBS Powerstroke diesel to come on the market, and finally that day has come. Meet the latest addition, my 96 (the black one). Everything on it works, not a single drop of fluid leaking underneath, keyless entry. I picked it up for $5000.
Thanks guys. That is the one scary part about it, it's right at 300k. I know for some of these 7.3's that's nothing. This is actually the first diesel I've ever owned, with that being said I'm not unfamiliar to them. Everything checked out to me, it sounds right, drives right and nothing seems out of place. It drives so much smoother and more comfortably than my 93 with 50k less miles.
Received 3,113 Likes
on
I am going to be making a list of things that need to be gone through and start inspecting everything and replacing what needs to be done. Anything that I should be looking for in-particular?
That truck looks to be in better shape than mine was with 79500 miles. If it were me, I'd repack wheel bearing and inspect rear diff/change it's oil. Of course check front end parts (ball joints, tie rod ends). Probably change coolant, motor oil, trans oil, tcase fluid, fuel filter, and run her. Nice rig man! Take her to 500k
injectors
radiator
IDM
Vale cover gaskets,
Under valve cover harnesses(UVCH)
Door panels, seats, dash pad, door hinges
COMPLETE suspension(worn bushings,springs,etc)
Auto trans in stock form is only really good for 100k. So I will assume it has had one or 2 already..
Everyone just thinks because the engine runs a long time the rest of the truck does too. But they wear out just like every other truck
Around here I couldn't find one in similar condition for less than 7500. But they're worth what someone is willing to pay for them, and I felt the price was good.
Complete engine harness
injectors
radiator
IDM
Vale cover gaskets,
injectors
radiator
IDM
Vale cover gaskets,
