Ignorant Question about Rebuilding Transmission
Old 08-27-2014, 09:26 AM
tombmd's Avatar
tombmd
tombmd is offline
Only with a load applied. It shifts into all gears easily enough. But it's only in 3rd, and only at just about 3,000 RPM where it pops right out.
Old 08-27-2014, 09:31 AM
tombmd's Avatar
tombmd
tombmd is offline
Looking at this picture I took of it, comparing it to Novak, it looks like an NP435, right?
Old 08-27-2014, 09:39 AM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,290 Likes on 2,446 Posts
Old 08-27-2014, 09:51 AM
77&79F250's Avatar
77&79F250
I had a trans that did the same thing, it wound up being the 3rd gear syncro that was bad.
Should not be that bad $ wise to get replaced, the hard/$$ part it pulling the trans/xfer case.
Drop the trans/xfer yourself, then take it to get fixed, unless you are brave and can read a book. Get in there and replace it yourself....some folks say.
I have read alot of folks do it themselves and its not that bad.
I love and support FTE 100% +60$, but I love information even better.
http://www.fordification.com/tech/PDF/NP435-rebuild.pdf
Old 08-27-2014, 10:38 AM
lafermedavid's Avatar
lafermedavid
lafermedavid is online now
T/C
for transfer case parts ck out NorthWest Fabricators.np205
Old 08-27-2014, 05:11 PM
OldMetal's Avatar
OldMetal
OldMetal is offline
I find this interesting, all a syncro should do is align the gears so they don't grind when shifting. I've drove and worked on many 5 speed non synchronized trannies, usually what happens is the splines on the gear and mayby the shaft as well become worn allowing the gear to **** and is then pushed out as pressure is applied.
I'm always learning so hopefully we will learn the outcome on this tranny
Old 08-27-2014, 06:31 PM
lafermedavid
sent you a pm.making sure you got it,,,,,,,,,,,,,,,cross member would have to be removed and then ****** tranny and lower with hoist from inside your cab or trans jack Tom go to your home page under contacts,the message I sent shows up there
Old 08-27-2014, 08:55 PM
tombmd's Avatar
tombmd
tombmd is offline
I'm not seeing the PM, could you re-send?
Old 08-28-2014, 12:28 AM
lafermedavid
contacts shows up there,,,public profile contact info
rtalich
20
07-08-2013 06:32 PM
Strokt350d
6.2L V8
06-24-2013 12:33 PM
codybear
08-25-2012 10:57 AM
usaftmroper
05-16-2012 12:09 AM
Meatco1
05-22-2007 03:58 PM
Quick Reply: Ignorant Question about Rebuilding Transmission
