somebody has had to have done this
Doing top end overhaul on 1991 f150 efi 4.9l 6cyl , just got head back from mach shop and need to go over rocker arm adj. as most of you know you can't adj with motor running due to air plenum in the way of valve cover to re-install after adj. it's been a long time since I've done this so looked up you tube video on it. basically i rotate motor until each respective rocker arm is at to point the valve is closed (up) and tighten rocker until push rod has "0" lash or play and tighten an additional half turn does this sound right. also the lifters were fine so i did not replace them, they should still be primed or pumped up. can i place them in a can of oil and pre-prime them again to be sure. any thoughts are always appreciated. First 4.9, changing timing gears, seals ect. 117,000 on odometer anything else to look for while it's out of the truck you can recommend again thanks.
changing every gasket and seal on engine, water pump,power steering pump,t'stat,sending units,checked timing gears (looks new)and giving motor
new paint job. everything in crank case looked good , lifters in great shape
oil pick up screen looks clean as a whistle. think i'm in good shape just want to get valves right on way back together.
Gans
11-13-2011 12:26 PM
1982fordf100
08-28-2006 05:18 PM
