Service engine light when towing
2005 2wd. Bone stock. 95,000 miles. FICM, Blue spring only.
After about 25 miles of driving. Towing a 30' goose-neck.(newer trailer) My service engine light will come on.
I have cleaned trailer plug and used dielectric grease. It is not a brake issue. Brake controller works as should.
Service light will reset after cycling ignition 4-5 times.
Again this only has happened while towing.
Any ideas?
Any ideas?
If I was a betting man I will say your truck is throwing an EGR code. Something like code po0404. Simple fix is to clean your egr valve and see if that fixes it. Do a search on here for proper removal and cleaning so as you don't ruin your egr valve. Stop at a parts store and have them run a check for diagnostic codes. It's free. If it only does it when towing I bet that's it.
But thanks for the heads-up.
I wonder if Advanced Auto ships. May not be worth the shipping though. I've heard that Autozone carries them in stock, if you have one of those nearby.
Do you have an Apple device, i.e. Iphone, Ipod, Ipad etc.?
