1985 F350 carb swap
1985 F350 carb swap
What are options to swap the carb on my 1985 F-350 460/auto/4x4?
The factory carb was removed and left out in weather. Another 4b double pumper was put on it before i bought the truck.
I removed that and put a holley 4160 750cfm 4b vacuum secondaries on it.
It just seems to be to much for the motor.
What would be a good replacement? A reman from the parts house is over $500.
750 VS should be fine for that truck.
What is it doing (or not doing) that bothers you?
Where did you get your 750?
Was it tuned for a much lighter vehicle?
The stock 4180 is said to be around 625 cfm
I am running a 0-80457 600 cfm Holley and it worked fine out of the box with just an idle mixture tweak.
It's nice not to have run a fuel log for dual inlets.
CFM is fine.
You've got 70ci on the 390, if the other truck would idle yours can too.
Where are the mixture screws set?
How is it pulling WFO?
If you want to keep it instead of selling it on, go through it and see how it's jetted.
Set it up at some kind of baseline.
Otherwise slag it on Craigslist and buy something you want.
Maybe an Edelbrock?
They rarely need much of anything out of the box.
Maybe an Edelbrock?
Someone on here put the Eddy 1406, which is 600 CFM, on his 460 and it worked well. I wish I could remember who that was. Anyway, that's the carb I'm running on my 351M and I thought it was just right but discovered with a wide-band AFR gauge that it was a bit rich. That might explain why it was just right for the 460.
I had a problem with the distributor where it would advance like it should when you got on the gas but it stayed advanced when the motor went back down to idle.
Replaced that, set the timing to 8* for now.
The previous owner changed the distributor to a MSD setup and a double pumper carb. He never got it running right and now I have it. The factory carb and distributor was trash from being out in the weather.
I pulled the carb off my other truck and stuck it on this. Truck fires right up and seems to idle ok. It just seems to me not to be as smooth of an idle as it should be.
Am I missing or over looking something?
I really think you need to fix the brakes and drive it before you can attempt to tune the carb.
Symptoms went from surging, to not as smooth as it should be, to a random skip at idle.
As Gary said, that's not unusual.
If it's eyewatering rich at idle you should adjust the mixture.
Warm the engine.
Turn the mixture screws in a 1/8 turn at a time and give it a little rev, then let it settle back down.
Do this until you find highest vacuum or highest idle speed.
Reset curb idle to 600 in gear.
Adjust idle mixture again, until highest idle or vacuum is found.
Recheck idle speed and you should be fine.
Gary and I both gave you options for 600cfm carbs if you want to go that way.
Holley shows your carb for a 429 application, it's not too big.
Warm the engine.
Warm the engine.
Warm the engine.
ilbiker
13
09-15-2013 10:54 PM
azfordf100man
09-20-2012 08:12 PM
kjett
11-11-2007 10:43 PM
Clifford II
19
05-08-2004 03:41 PM
