1979 f150 400m very loud rattling/scraping sound on startup.
I went to leave work earlier this afternoon and fired up the truck its a 1979 f150 with a 400m, re-manned crate engine, and the moment i fired it up, it had a sharp rattle scraping type sound coming from the engine, and what sounded like the drivers side valve cover, i thought something terrible had happened to my engine, but it never made a peep on the way to work or ever before.
i shut the truck off after walking around it trying to figure out the source of the sound and started it back and up BAM its gone completely! no noise or nothing.
i have no real clue as to what it was or what it could be. my oil pressure was good it was at 75 psi
Pull the starter and inspect the drive teeth and insp the flywheel for chipped or broken teeth. Easy fix if it just the starter, also insp the flywheel teeth edge to be worn, cause by the starter not engaging fully.
Starter Service repair diagnosis symptoms bad starter help
FordNFishinLover
08-05-2009 11:41 AM
