New to Forum - Just bought an 87 F250
Hello everyone! I just bought an F250 single cab 5.8L naturally aspirated. 2wd, auto tran.
I am an experienced weekend mechanic but its been years since I worked on an engine like this. I am in the process of sourcing a Helms if I can find one if not then a haynes. I have some questions about the current engine set up. I will start a different thread for each so as not to confuse the issue.
I am trying to sort out the vacuum lines (or lack thereof) I have the vacuum diagram on the fan cowling. and there are a lot more lines then i see in the engine. Under the carb, which I believe to be a Holley 4160 there is nothing connecting to a vacuum line marked in the holley 4160 diagram as "Full manifold vacuum source connects to air cleaner and/or air pump diverter valve".
is this an issue? where (if anywhere) should this be connected and is it relevant on this engine set up?
zonker
112
06-25-2017 05:20 AM
jasonzbtzl
10-23-2012 10:42 AM
