Under bed gas tanks
Old 08-19-2014, 04:59 PM
ZFLASH's Avatar
ZFLASH
ZFLASH is offline
Under bed gas tanks
Before anyone says try the search,I did,I put in, fuel tanks,gas tanks,and after market gas tanks. Then everything and it's dog comes up,but no info on the subject. I'll be re-doing my bed in the coming months,so I was thinking while I was doing this,I might as well install a new under the bed gas tank. Now my rear end has been cut out and a 4 link installed,limiting mounting area. I was looking at a '67-'70 mustang 20-22 gallon tank,saw one from Kentucky Mustang with sending unit for $159. Is this a good unit and price,or is there a better way. Thanks Axe before hand and everyone else. L8R ZFLASH
Old 08-19-2014, 05:03 PM
drptop70ss's Avatar
drptop70ss
drptop70ss is offline
Depends what you want. I wanted a side fill gas door on the fender so I used a 22 gallon chevy van tank. My luck with a gas fill door in the bed floor the day I need gas will be when there is a ton of stuff in the back.
Old 08-20-2014, 01:22 AM
smallello's Avatar
smallello
smallello is offline
I still haven't done this yet but I am leaning toward this tank. It should fit between the cross members so they don't have to be moved.
https://www.ford-trucks.com/forums/1...fuel-tank.html
Old 08-20-2014, 06:53 AM
jniolon's Avatar
jniolon
jniolon is online now
old and in the way
Old 08-20-2014, 04:16 PM
ZFLASH's Avatar
ZFLASH
ZFLASH is offline
Originally Posted by jniolon
Thank you,this is one of the links I was looking for. L8R ZFLASH
Old 08-21-2014, 09:16 AM
rustybits's Avatar
rustybits
rustybits is offline
I put a saddle tank out of the same era panel truck, using thestock mounting brackets and straps. I relocated it slightly aft and I modifiedit to suit filling from the stock location on a pick-up (passenger side), Ialso modified it to accept my Dodge Dakota electric fuel pump and pressureregulator. So far everything seems to be working fine, and it leaves room forthe spare tire at the back, and a motorcycle in the box.<o></o>
Old 08-21-2014, 11:57 AM
AXracer's Avatar
AXracer
AXracer is offline
Mine is a panel, so I can't help much.
Old 08-24-2014, 10:11 AM
epp's Avatar
epp
epp is offline
bought my tank from tanks inc. figured out how much room i had to work with and found one that would work. Been happy with it
TANKS Inc. gas tanks for street rods, muscle cars, custom cars and trucks
Old 08-24-2014, 10:17 AM
carnut122's Avatar
carnut122
carnut122 is offline
It depends on if you're carbing or injecting.
Old 08-24-2014, 09:14 PM
ZFLASH's Avatar
ZFLASH
ZFLASH is offline
Thanks to all who have responded, carbed for now,injected later. I'm re-doing my tubbed bed soon, that's reason I'm looking. My thinking is to have installed since the bed will be out,just don't hook it up until I do the LS conversion. So maybe buy for it to be used with fuel injection, thanks. L8R ZFLASH
Old 08-25-2014, 05:52 PM
carnut122's Avatar
carnut122
Mine is injected, so I found a tank that I could drop a 1995 Mustang GT pump unit into. I opted for the 1973 Mustang tank that had a hole for the pump on the top and the sock sits(after slight bending of the FP bracket) right off of the bottom of the tank. The only drawback is the lack of baffling(that I know of-I wish I checked it out more carefully). So, a low tank and a steep incline makes me nervous. I put the gauge sending unit in the side hole. I'm not sure how this would play with your carb situation.
Old 09-10-2014, 12:14 AM
Jetman's Avatar
Jetman
Jetman is offline
I am wondering if a guy could run a fuel filler out the left side of the frame with the 22 gallon Mustang tank and place a door on the rear of the fender.
Old 09-10-2014, 12:47 AM
ZFLASH's Avatar
ZFLASH
ZFLASH is offline
I've seen pics of this and it's possible, just depends on which way I and you want to go. Also,I've seen them run it out the back end and hid behind the license plate like on some older cars. Either way would be nice,L8R ZFLASH
Old 09-11-2014, 01:17 PM
Ford52F2's Avatar
Ford52F2
Ford52F2 is offline
It's been a long time ago but I install a 74 GMC fuel tankunder my 52 F2. May want to check if my post are still here?
Axe good to see your still here.
Ford52F2
Old 09-11-2014, 03:43 PM
smallello's Avatar
smallello
Quick Reply: Under bed gas tanks
