First time ever replacing a water pump.. help please
Got it! Putting a belt back on didn't help, I tried 2 different ones but couldn't get them tight enough to make a difference. What did help was using the tool that came with the fan clutch set I borrowed, to hold the 4 bolts and managed to get a socket on one bolt at a time to loosen. Worked like a charm.
Now I'm stuck again, trying to get the small coolant hose off the top of the water pump. It's not wanting to budge one bit. Not sure what I should do here...
If that doesn't work, you can always cut it off. I think there should be enough slack in the hose to reconnect it, or just get a new piece of hose. If I recall it runs to the cab heater and is just a regular section of heater hose.
Ended up just tearing off the hose, going to buy a new one later. I've got all the bolts removed from the water pump, and put into their corresponding holes on the new pump so I don't mix any up. The pump doesn't want to come off, but I'm sure all of the bolts are out. Should I try to pry it off with something gently?
Also, I thought of another couple questions that I should ask:
1. I don't have a torque wrench. I've read that the bolts should be tightened to 14 lbs torque, I'm not particularly strong so should I just try to get them as tight as possible? I don't want to mess anything up, obviously.
2. I bought a re-manufactured pump. It doesn't look so bad, but there's a few dings and scratches. Should I get some sandpaper or anything and file it down? I'm kind of apprehensive about doing this and messing it up.
3. I read in one thread, somebody used paint thinner to clean the pump surface where it meets the gasket, as well as all of the bolts. Do I need to do this?
Thank you! Hoping to get this done and my truck running again by the end of the day.
Got the pump off. Just took a little more force than I was using. Now I'm stuck on trying to get this old gasket off, it's really stuck on there good. I have razor blades, sandpaper (somewhere, I don't remember what grit), PB Blaster, WD-40, throttle body cleaner, MAF sensor cleaner... hoping to not have to buy anything else as I am short on funds at the moment. What works best for you guys? I read that using a razor blade at a 90 degree angle to the surface is safe and works good, so I was doing that for awhile, but it's pretty tedious and taking a long time.
Aside from that, I still have those 3 questions above ^ that I need to know before proceeding. Harbor Freight has a torque wrench that will go to 14 lbs, thinking about just buying one and then taking it back after I'm done. Do all of you generally use a torque wrench when doing this?
Also, I realized that I need to take the heater hose pipe off of the water pump.. it's stuck on there REALLY good. There was some kind of thread lock tape on it, that I scraped off the parts that were exposed. I don't have a big enough open ended wrench, but it seems to me that it is a 7/8" size. I'll probably just pick up one of those at Harbor Freight too, and return it when I'm done along with the torque wrench, unless you guys have any better ideas.
Thank you,
Zac
Thank you,
Zac
#28
A little late, but this is golden.
https://www.ford-trucks.com/forums/1...new-trick.html
Use some locktite on the threads when you put the fan clutch back on. Now is a good time to do your t-stat if you haven't already done it too.
#29
#30
Not the hose, I was already planning on getting one of those (it was stuck, had to cut it off). I'm talking about the short pipe that screws into the water pump, that the hose fits onto. The water pump I got didn't have one, so I've got to get this one off somehow.
And thanks for the help with the other questions. Good to know I'm not going to mess anything up.
