[Discussion] 4.10 POSI on a 300 I6
I was searching around craigslist's auto parts section today, and stumbled across a posi-trac 4.10 geared 8.8 rear end from a 1st gen Ford Lightning. It seemed a little heftily priced at $450, but I don't have a lot of experience in the secondhand differential market. My F150 has a 4.9L inline 6, with the M5OD 5-speed manual, would this be a good combination with the 4.10's higher ratio? How much would you ask the seller for it?
Don't know much about the pricing on the rear Diff, but I had an 86 F150 St8 6 300 and 4sp with an unbelievable Granny gear. It also had a 4:10. I got like 10mpg with that truck. I was a great work beast but don't plan on trips. I finally sold it off about 10 years ago and the guy that bought it is still using it to haul his black top tank around with.
I run 31's, I sit at 2500 going 75 right now. And if i find some lightning wheels I might eventually lower the truck a bit
Assuming the 0.75: overdrive is right, 2700 rpm with 4.10s and 31s would be 81 mph. 60 mph would be 2000 rpm, 70 mph is 2330 rpm. Not terrible, but certainly not a good place for decent mileage with a 300. And you probably don't need it going that fast for decent power either. I'd want taller gears.
YES PLEASE Help
In 4th gear I want to be able to run 2500 rpm while towing 6000 lbs. flat ground. What rear end ratio do I need ?
WD4B
02-22-2012 11:36 AM
ewellman
07-25-2003 11:35 PM
