Speedometer cable - 91 AOD in 71 F100
I have a 5.0 EFI and same year AOD From a 91 T-Bird in my 71 F100.
Questions on a suitable speedometer cable. I have been told I will need a cable that is VSS capable. Not running cruise, using a stock 71 F100 speedometer. So, is there a way around this? Other than swapping tailshafts from an earlier AOD?
I read somewhere a 80's era big bronco speedometer cable will work correctly. Anyone heard of this before?
Yes, I know I will need to get the right gear so my MPH reads correctly. First things first.
The computer may freak out a bit without a speed signal, but it's not too hard to fix. Many trucks up to 94 had the speed pickup at the tailhousing with the speedo cable feeding through it just like a normal clamp. I would suggest a bit of junkyard diving to find what would work for you.
Sent from my C771 using IB AutoGroup
I bought this one. It should work for you. http://www.summitracing.com/parts/lok-sp1502u/overview/
fatfenders56
06-06-2012 04:33 PM
mtflat
07-09-2002 08:42 AM
