4V Intake Manifold
Old 09-08-2016, 03:30 PM
My1964ford's Avatar
My1964ford
My1964ford is offline
Originally Posted by mikey1968
Got it all to work. I hooked up the manual choke and had to swap the parts from the 2V. I even had to swap the throttle shaft to get it all to line up.
I'm hoping to make the same 4bbl swap as you on my 64. Can you give me any specifics about the swap and how you made it happen? Also how does your truck run now compared to before? Thanks in advance!
Old 09-09-2016, 05:57 AM
mikey1968's Avatar
mikey1968
mikey1968 is offline
Well.....I'm troubleshooting a vacuum leak and am thinking the sealing surfaces between the carb base, spacer and intake are not lining up. This is a common problem on the small block Ford with a Performer intake. Also looks like someone else has had this exact problem before. Carb Spacer to Accept PCV Feed
You can follow my issue here: https://www.ford-trucks.com/forums/1...l#post16556314
HoustonGuy
04-24-2012 10:49 PM
daggerNC
01-25-2008 08:33 AM
jaye
03-15-2006 02:41 PM
Little Bro
03-04-2004 09:04 PM
youdog99
11-27-2002 04:12 PM
Quick Reply: 4V Intake Manifold
