anyone know what kind of TPS this is
Old 08-15-2014, 09:04 AM
sweet55's Avatar
sweet55
sweet55 is offline
its a 2007 4.6, every auto parts store i go to want to give me the same thing that looks like its a part of it but the mounting is completely different. the connector is the same but that's about it.
any help would be appreciated.
thanks
Old 08-15-2014, 10:03 AM
85lebaront2's Avatar
85lebaront2
85lebaront2 is offline
Old School Hot Rodder
2007 should be a drive by wire, and that would be the throttle actuator. If I remember the TPS is on the throttle inside the cab. You have three redundant sensors in that unit which is called and Electronic Throttle Control module (ETC). What makes you want to replace it?
Old 08-18-2014, 03:42 PM
sweet55's Avatar
sweet55
sweet55 is offline
every now and then when i'm driving it it will have no response to the petal and chug as i'm pushing it then it will finally catch up. i had the same issue with another car and it turned out to be the throttle position sensor.
do you think it may be something else.
thanks
mike
Old 08-18-2014, 09:30 PM
85lebaront2
On your truck, the TPS is inside on the throttle pedal, yes they do go bad, there is a re-calibration procedure for them, I don't have it where I can look at right now as I am about 150 miles from home. Your TPS tells the EEC what throttle you have applied, and the EEC commands the ETC to open the throttle.
If you have an analog multimeter, unplug the TPS and check the resistance, from one set of connections it will always read the same no matter what you do with the pedal. From one of those to the third (and you may have two or more sets) it will vary as you move the pedal. It should be smooth, not jump or show an open circuit. If it is erratic, it's bad.
Last edited by 85lebaront2; 08-18-2014 at 09:34 PM. Reason: Additional information added.
guitarpicr
02-26-2017 08:02 AM
AGrayson84
2004 - 2008 F150
11-07-2016 09:24 PM
joeyd61
03-05-2013 02:18 PM
rondogw
11-21-2010 12:16 PM
Torvvald
03-10-2007 06:52 AM
Quick Reply: anyone know what kind of TPS this is
