Another **** headache (P0264, P1271, P1272)
SO finally got the the motor in and everything figured out. Was running FLAWLESS for about 70 miles or so. Today after fixing a small fuel leak, fired it up and was around 2500 RPM when it started running rough and smoking black, even at idle. Checked codes, came up with
P0264 Cylinder 2 Injector Circuit Low
P1271 Cylinder #1 High To Low Side Open
P1272 Cylinder #2 High to Low Side Open
Did a buzz test and all were fine, so they're getting signals. While running, i unplugged the driver side rear harness and there is almost no change (still runs rough) Im assuming this is the plug for cylinders 1/2. Plug and harness looked fine, not burnt, but haven't checked under the valve cover. Is the next step pulling the VC off and seeing what it looks like under there? Its weird that it ran fine then all of a sudden started this. Brand new VC gaskets with only 70 miles on them. Any guidance appreciated guys.
Good diagram, saved. So I will never understand why the truck gremlins decide to **** in my cheerios, but i swapped the IDM with aarons and the problem is gone. Cleared the codes, none came back. Crazy how it was working fine one second, then the next went bad. Appreciate the tips. For anyone else finding this with the same issue, Here is another link i found. hopefully this will serve as help. https://www.ford-trucks.com/forums/8...-inj-code.html
Sorry, i somehow just saw these posts. They were running fine lol. I still haven't been able to see what they can do as i haven't made it through my breaking period on my clutch. 425 more miles.....
MagKarl
05-13-2008 03:13 PM
