only starts with starting fluid
I have a 1990 F150 4.9. I have replaced the fuel pump, fuel filter, fuel lines, and fuel pressure regulator. I have replaced the distributor, spark plugs and coil. I have good spark, and pressure on the fuel rail. The truck will run, but will not start unless I spray some starter fluid into it. Any advice on how to get this truck to run would be great.
When you say "The truck will run, but will not start unless I spray some starter fluid into it"
Do you mean it needs a shot of starting fluid to get it running but then it runs until you shut it off ?
Or it runs on the starting fluid and only on the starting fluid?
Believe it to be the latter but not real clear in your wording.
And if the latter you need to verify power to the injectors and the computer is actively firing them.
A noid light is the best method but hand on them feel for a "clicking" vibration, a long screwdriver held to ear as stethoscope etc work in a pinch (don't just verify one).
christ
17
03-10-2020 09:10 PM
tbird1inok
08-12-2010 03:03 PM
mike L
24
09-26-2004 09:16 AM
