My NEW 1965 F350
Old 08-11-2014, 08:19 AM
jjreagan's Avatar
jjreagan
jjreagan is offline
My NEW 1965 F350
Just came back from Bismarck, ND where I picked up this solid F350. Needs some TLC but for $200 purchase price, I thought it was a good deal. I was the only bidder on ebay for this. It has been in the barn and the cab mounts are solid. It started up, but I couldn't keep it going. Probably will run once I have time to go through it. Numbers Dummy, could you decode this VIN? Thank you!
Old 08-11-2014, 08:55 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by jjreagan
F35 = F350.
D = 352 2V
R = San Jose CA Assembly Plant.
648836 = 1965, assembled February 1965.
132" Wheelbase.
M = Wimbledon White.
F350, 10,000 lbs. GVWR
581: 5 = Red Crush Vinyl & Red Wicker Pattern Vinyl / 81 = 81A Standard Cab.
N = New Process 435 4 Speed Manual Transmission.
23 = Spicer/Dana 70 Rear Axle / 5.13-1 / 15,000 lbs. Rear Axle Capacity.
10,000 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
71 = Los Angeles (SoCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
Old 08-11-2014, 09:22 AM
Shadowrider123's Avatar
Shadowrider123
Shadowrider123 is offline
A working truck for sure.
Nice find, there is a similar 67 F350 here for sale, if had a place to park it and something to do with it, I would buy it.
Old 08-11-2014, 09:58 AM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
Wheelbase has to be more than 132"........maybe it's been stretched?
Cool truck and a smoking deal!
Old 08-11-2014, 10:31 AM
jjreagan's Avatar
jjreagan
jjreagan is offline
1965 F350
Yea it is pretty long. It barely fit on my 16+2 trailer. I will have to do some measuring. Thanks for the decoding Number Dummy! The owner said he picked it up in California. The bed was manufactured in Long Beach. It still has the original mud flaps on it that says: "Paramount Long Beach". Thanks all!
Old 08-11-2014, 11:50 AM
arctic y block's Avatar
arctic y block
arctic y block is offline
Great save. Nice start. I have a 66 F350 that I am parting out if ya may need anything.
Old 08-12-2014, 09:32 AM
NumberDummy
At one time, there was Paramount Truck Body - located in Long Beach.
Old 08-12-2014, 10:11 AM
jjreagan's Avatar
jjreagan
jjreagan is offline
F350
I wondered if they were still around- guess not then.
Old 08-18-2014, 07:58 AM
jjreagan's Avatar
jjreagan
jjreagan is offline
1965 F350
Well I had time to work on this this weekend. It wouldn't start and was not getting fuel. I determined the fuel pump was not working so I put a new one on and replaced a couple short fuel hoses that were way old. After some fresh gas it fired right up and then the carb was leaking from the accelerator pump. I went ahead and put a kit in the carb. After all that it fires right up and runs pretty good. Oil pressure is right at 60psi. Next I worked on the brakes. It didn't have any when I picked it up. There was not any brake fluid in it. I topped it off and the pedal came to life. I am not seeing any leaks though, so I am not sure where it had gone in the 10 years it had been sitting. So far I am making progress!
Old 08-18-2014, 08:07 AM
jjreagan's Avatar
jjreagan
jjreagan is offline
Wheels
This truck has 16" tires on it. They look like they probably came on it but I am not sure. I thought most of them had 17.5" or 19.5"? Does anybody know if these 16" all around are oem? Also the front wheels do not look to be two piece or multi piece wheels- am I correct in this assumption. You all are a great help!
Old 08-18-2014, 08:17 AM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
Post some pics of your wheels if you can........16's would be widow makers or lock ring type .
Old 08-18-2014, 08:33 AM
jjreagan's Avatar
jjreagan
jjreagan is offline
I will have to get some pics for you. I was wondering about them being widowmaker wheels, but when I looked at the inside of the front rim I couldn't see a joint where they split. There was a lot of dirt though so I might have just missed it!
Old 08-18-2014, 09:30 AM
NumberDummy
1953/66 F350's came with 16" x 5.5" - 17" x 5.5" - 17.5" x 5.25" - 19.5" x 5.25" 6 lug wheels on a 7.25" bolt circle, the only Ford trucks to use this pattern.
The 16" wheels are very hard to find.
Old 08-18-2014, 01:11 PM
arctic y block
I have 6 16 inch spit rings in great shape with radial tubes, liners, and tires looking for
a good home. They are 6 lug on my 66 F350.
Old 08-19-2014, 11:17 AM
jjreagan's Avatar
jjreagan
jjreagan is offline
here is a pic of the front wheel, looks like they are the lock ring type.
Front 16" wheel and tire off my F350
Close-up of the front wheel and tire.
hollygreenf250
03-29-2019 07:36 PM
HST
2017+ Super Duty
09-26-2018 08:09 AM
rsh1966
04-22-2018 10:12 AM
Cavalier240
2017+ Super Duty
17
12-23-2017 01:10 PM
Curated Content Editor
1999 to 2016 Super Duty
10-13-2017 01:39 PM
Quick Reply: My NEW 1965 F350
