Quick VIN decode
Old Mar 27, 2019 | 08:22 PM
hollygreenf250's Avatar
hollygreenf250
Quick VIN decode
Might be buying this truck as a roadtrip truck, it'll be a handful but fun. Thanks in advance!
Old Mar 27, 2019 | 10:59 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F35 = F350.
A = 240 1V I-6.
C = Oakville Ontario Canada Truck Assembly Plant.
746761 = 1966.
132" Wheelbase.
J = Rangoon Red.
F350, 10000 lbs. GVWR
5 81: 5 = Red Crush Vinyl & Red Wicker Pattern Vinyl / 81 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
23 = Dana 70 Rear Axle / 5.13-1 / 7,400 lbs. Rear Axle Capacity.
10,000 lbs. Gross Vehicle Weight Rating.
129 net HP @ 4,000 RPM
B46478:
B4 = Ford Motor Co. of Canada Ltd. - Midwestern Division.
6478 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
Old Mar 28, 2019 | 11:48 AM
hollygreenf250
Thanks NumberDummy!
Old Mar 28, 2019 | 05:16 PM
James_Western_Canada's Avatar
***Just in case you care, 746761 = 1966. and would have been produced in Sept/1965......
James
Old Mar 29, 2019 | 07:36 PM
BarnieTrk's Avatar
BarnieTrk
"...as a roadtrip truck, it'll be a handful but fun."
If you were to get it, I suspect you would plan on at least changing out the engine and rear gears, correct?
If not, a truck that heavy, with a dinky 240 6cyl, and a 5.;13 rear gear.....even on a flat road, empty, that baby would be wound out by 50mph and give you 5 mpg!
That beast would also have a sold front axle, correct? So, yeah, it would ride like a dream..........
But, hey,,,,they all need luv, right?
BarnieTrk
osbslinger
Large Truck
Sep 15, 2018 10:35 AM
Travis0202
Feb 11, 2017 04:28 PM
ford390gashog
Apr 28, 2016 10:20 PM
IronPlayer66
Jun 8, 2015 07:22 PM
TheOtherStyle
Large Truck
Oct 23, 2014 10:25 AM
