7.3 idi ip gear housing leaking
I'm getting ready to fix a leaking ip gear housing on my truck (where the housing meets the block, on the driver side, right above the water pump). I've seen posts of a few ways to do it and not disturb timing. Just wanted to know the BEST way to get this taken care of from someone who has done it with success. Thanks in advance!
Yup; that happens. You need new silicone/RTV, a wire brush and other instruments to get the old RTV off, and plenty of patience.
What I recommend is that you pull the end-cap off the IP cover(two bolts, front of it), so you can see inside. Rotate the engine until the dowel pin is upwards.
Unhook the battery, put it in neutral, whatever it takes to make sure you don't accidentally rotate the motor.
Unscrew all of the 8 injector lines at the injectors. Disconnect the fuel-filter-to-IP supply line.
Now, just unbolt the whole thing, turn it upside down and clean it. Clean the mating surface as well.
When you put it on, you just need to make sure that that dowel is straight up, and you'll be on the correct tooth.
Put it all back together, bolt it down and it should be good.
Seriously... it's not that big a deal; as long as you get the teeth in the same position; even one tooth off is easily noticeable -- it's 7 degrees of timing gear rotation, after all(14 degrees of timing). And, even if you somehow manage to become one tooth off, the truck can still be started(if it's one tooth retarded, it will barely start and have no power, puff lots of smoke. One tooth advance will be very loud and clattery, and have no power). It's pretty obvious.
wahlturfcare
09-24-2017 02:05 AM
occb2
06-19-2007 09:09 PM
davewild
01-11-2005 05:52 PM
