6.4 antifreeze 2010
6.4 antifreeze 2010
Hi All,
I recently bought a 2010 f-250 with a 6.4.
I want to change all the fluids, filters to start the maintenance program .
Since I work at John Deere and deal with Tier 4 engines , I was wondering your thoughts as to using the yellow J.D Cool-Gard II antifreeze. Designed for use in Tier 4 diesels and good for 6 years. ( with proper conditioning)
Thoughts??
Or should I run the red Rotella ELC ?
Thanks,
Duhnis
Thoughts??
Thanks,
Duhnis
As Senix stated stick to the factory fuel and oil filters. Aftermarket just don't seem to fit right and i personally have had issues with them. As for the coolant i use
http://www.cumminsfiltration.com/pdf...LT15070-GB.pdf
We had a problem with our guys mixing coolants of different types because we have so many different pieces of equipment and trucks. In addition each manufacturer claims you need to run a specific coolant. This coolant mixes with all the different machines we have so we eliminated the issue. The coolant is working well for us with no issues, but review it to make sure its right for you before you consider it.
Few quick tips:
1. Follow the severe maintenance schedule
2. Test the nitrates in the coolant frequently
3. Don't idle the truck excessively
4. Use quality fuel from a known source ( The fuel systems on these engines are not forgiving to water in fuel)
5. Watch your oil level to make sure its not growing. ( Can be an indication of fuel in the oil. The DPF emission system's on these engines can attribute to additional fuel in the crankcase which can result in additional wear or failure on engine components if left unnoticed. )
Optional:
1. Use a good fuel additive such as Opti-Lube Diesel Fuel Improver | Grease | Oil Fortifier
2. Use synthetic oil CJ-4 approved
3. Take Oil samples
Few quick tips:
Optional:
3. Take Oil samples
So after doing a little research, Shell ELC doesn't provide a Ford rating but does provide a Cummins rating of 14603 in which Motorcraft Gold coolant confirms to. BUT, Only the ULTRA ELC meeting the Cummins rating. Rotella ELC has a rating of AEB 90.47. So is it recommended to go with the ULTRA ELC?
blrman1962
03-01-2007 07:53 AM
