2006 6.0 Crank - No Start
My 2006 Crewcab Dually would crank with no start a few years ago. I stopped at a drive thru to order and when I started the truck back up it was a long crank with a strange idle then cleaned up. I didn't think anything more about it and drove 25 miles to work. Later that day I went to restart my truck with no luck and had it towed home.
In the meantime I have been lurking and trying to learn what I can about 6.0s.
It has been sitting in the driveway for 2 years till this week I decided to figure out what is going on with it and get it going.
I purchased a ScanGauge II and charged the batteries up.
FICM Main Power : 49-50volts
SYNC: 1
ICP: 0
IPR: 85%
I looked at the oil filter housing and noticed the oil was low in the housing. And also no oil pressure reading on the dash gauge. Upon closer inspection of the filter I noticed the top of the filter had popped up and was level with the teeth that seat in the filter housing cap. I replaced the filter and check the oil level and during cranking it registered oil pressure on the dash gauge and filled the filter housing.
I unplugged the ICP sensor and then got a reading of 1500 and the truck cranked and acted like it was trying to start but no luck.
I figured the next step is to look at the IPR to see if the screen has failed and something stuck in it.
This is a little overwhelming since this is my first journey into the world of diesels and when I first looked at this 2 years ago....I saw something like 26 different things that could keep a 6.0 from starting......I said the price of diesel fuel......it can sit.
Now I am working on the house and it would be nice to have a truck to run back and forth to the dump and Home Depot.
Thanks in advance.......
Signed....Overwhelmed
SYNC: 1
ICP: 0
IPR: 85%
SYNC: 1
ICP: 0
IPR: 85%
SYNC: 1
ICP: 0
IPR: 85%
The values I mentioned were while cranking. The oil filter I think I put in this time is a Fram I will look at the box tomorrow. The cap is the stock cap. I watched the video and will be buying Motorcraft from now on.
No mods have been done to the truck. I did get an EGR code a few weeks before all this happened years ago...and I disconnected the valve. I had planned on cleaning the valve once I got it to the point where it would start.
To get to the IPR do I need to take the turbo off or can I remove the IPR by the way of the FICM and moving the harness?
How many miles do you have on the odometer?
https://www.ford-trucks.com/forums/1...p-threads.html
