obd will connect for codes except for abs codes
Hello, I have a 1999 f150 4.2l that the abs light comes on going slow, under 25mph. Replaced speed sensor still there. Hook up my scan tool and get connection error. Only in abs mode. Check fuses and power point's. Scanner works on a buick fine. Any help would be great.
Resolution -
I need a replacement ECM or my current one needs to be reflashed. My truck starts, runs, and drives for now - I'm not playing with it.
On the ABS front, there is not ABS code reader for this year. You have to short the wire and read the blinking codes. I my case is blinked 12 times and I replaced the master cylinder. The sensor at the bottom of the master cylinder was corroded.
