I have a couple questions...
Main one is there anything in the valley that can leak coolant which will run down the front of the motor? I just replaced my water pump again but on the driver side it looks like the coolant is coming from somewhere else.
And what is the name of the app for smartphones? Or a link for it
on
Usually if the leak is big enough it will go down the drain hole in the valley and come out next to the starter. there is not to much in there with coolant, back of t-stat housing, I just put in a diesel-site 203 stat and broke the back bolt off, knock on wood its not leaking yet and at the same time hooked up my coolant filter. I know I cant leave a broken bolt even though it's not leaking, so I have to order a new housing as well and drill and tap, than put in ELC and I'm done with that part.
exbxtoy
01-28-2016 02:37 PM
fridgeddiesel
04-16-2014 12:49 PM
ngng
25
03-23-2009 12:12 AM
freethefood
07-20-2004 10:49 PM
