Modular V10 (6.8l)
O6 f250 horn not working
Old 07-18-2014, 10:18 PM
buddy26's Avatar
buddy26
buddy26 is offline
The horn is not working I changed the fuse for the horn and still don't work. The cruise control still works and the air bag light is not on. I can here the relay making a clicking noise when you push the horn just no sound. Does it sound like the horn is gone bad or could it be the relay? Thanks
Old 07-19-2014, 10:33 AM
Hank85713's Avatar
Hank85713
Hank85713 is offline
Check the connections AT the horn itself, they may have corroded, come loose. It is also possible that you have a bad relay, or tha the hot wire to the horn has corroded, broken as I noted above.
Old 07-20-2014, 05:05 AM
JWA's Avatar
JWA
JWA is offline
Received 1,409 Likes on 1,112 Posts
Run a wire directly from the battery to the horn itself, touching the input tab---if it works you have an electrical path issue. If it doesn't then its the horn itself.
If its a path problem I'd suspect the relay contacts. Since it would be supposedly operating the lack of current to the horn suggests the contacts inside the relay housing.
Old 07-20-2014, 09:10 AM
buddy26's Avatar
buddy26
buddy26 is offline
Thanks I will try everything that was mentioned and see what happens and report back
Old 08-21-2014, 11:05 PM
buddy26's Avatar
buddy26
buddy26 is offline
Finally had time to take apart and check everything it was the horns themselves. Replace horns with a bad boy horn and everything works now. Thanks
johninraleigh
04-17-2007 04:20 AM
askopp
11-27-2006 10:30 PM
cjcathey2002
12-10-2003 07:44 PM
Hi Ho
Electrical Systems/Wiring
04-21-2003 12:17 AM
cobraguy
04-21-2002 12:57 PM
Quick Reply: O6 f250 horn not working
