No rear running lights
Old 08-02-2014, 11:11 PM
ssurfer24's Avatar
ssurfer24
ssurfer24 is offline
Hey all,
I have a 1989 F250 7.5L 460 and have a small electrical problem I can't seem to track down. When I was pulling my trailer up a bumpy road I lost my rear running lights on the truck which in turn affected the trailer also. I have front running lights, dash lights, brake lights and turning signal lights but no rear running lights. I've checked all of my fuses under the dash and they are all ok so I'm thinking a wire got fried between the front and rear but I'm not sure so I thought I'd jump on here and ask for some guidance.
Thanks
Derek
Old 09-14-2014, 10:44 PM
ssurfer24's Avatar
ssurfer24
anyone???? and if the truck sits for a few days the battery gets drained... that's a new one so something is shorting out I'm sure...
Old 09-15-2014, 08:37 AM
barkfarm's Avatar
barkfarm
barkfarm is offline
Power in the battery draining maybe the alt going bad. the wire is a real pain my 1992 f350 was had by a knife nut cut wires under big time no fuel gauges lots of wires cut. need to check the brown wire under the truck this is the color of the wire for the running lights.
Old 09-15-2014, 08:48 AM
Mike1's Avatar
Mike1
Mike1 is offline
Running lights on truck and trailer lights out, check the connection where your trailer connector is hooked into your truck wiring harness, it could just be a corroded connection. Depending on the trailer connection type, if it's OEM then you should be able to unplug it and plug your wiring harness back together to see if you get running lights. If it's an Aftermarket connector, those usually have those crappy clamp over wire type connectors that have a tendency to go bad.
Old 09-15-2014, 01:36 PM
barkfarm's Avatar
barkfarm
barkfarm is offline
And put dielectric grease in the plugs work great and help stop corrosion of the pins.
cekm2010
15
03-17-2011 09:37 PM
FLJ
03-03-2009 05:41 PM
Brcuda
1999 to 2016 Super Duty
09-22-2008 07:52 PM
984x4F150
1997 - 2003 F150
18
09-24-2003 05:58 PM
white99
1997 - 2003 F150
03-13-2002 03:16 AM
Quick Reply: No rear running lights
